587,726 active members*
3,517 visitors online*
Thread: no support
Results 1 to 4 of 4
    Feb 2005
    52
    no support
    IMS used to provide quite abit of help for Deskcnc but I believe they quit about 2 years ago--or maybe they just charge for support now-I don't know. If they still sell the product you would think they would back it up.
    Dec 2004
    1865
    I don't know about there support policies but if you have a question I will try to help.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Feb 2005
    52
    questions
    along with the deskcnc software I bought a gen 1 and a gen 2 board but never used them. several years back. I am now trying to get them running but they won't be recognized. Is that a standard serialport cable or a special one. after reading some information about the board it is not clear what all has to be running before it is ready for recognition. any Ideas?
    Thankyou
    Dec 2004
    1865
    Quote Originally Posted by ljd10 View Post
    Thankyou
    They use a standard serial cable. You have to go to the Deskcnc setup tab and input the proper com port. You also have to select if you have a 2nd gen board or not so the same setup will not work for both boards.
    You will also have to provide power to the board before it will do any communications.
    I have used them under Win95 through Vista with either built in serial ports or USB to serial adapters so they should work for you.
    The manual is located here. It is very helpful in getting it all setup.
    http://www.deskcnc.com/DeskCNCManual.pdf
    Hope that helps.
    Mike.
  1. Support.
    By Jens H in forum Automation Technology Products
    Last Post: 09-30-2009, 02:51 PM
  2. Support
    By Brendan in forum Milltronics
    Last Post: 03-17-2008, 03:31 PM
  3. PC CAM support
    By tengo8 in forum Bridgeport / Hardinge Mills
    Last Post: 03-04-2008, 01:25 AM
  4. APT Support
    By cimlinc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-24-2006, 06:01 PM
  5. Milltronics support
    By harttool in forum Milltronics
    Last Post: 05-19-2006, 12:00 AM
