588,159 active members*
4,918 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > NO THC for waterjet cutting, so how critical is nozzle standoff distance?
    May 2007
    88
    THC allows people to cut corrugated material and have a warped workpiece or even an unlevel cutting bed. But i'm not aware of any similar technology for waterjet machines. So how critical is nozzle distance from workpeice for quality of cut, etc???? I'm sure it varies with material being cut.
    Sep 2008
    Height control for waterjet cutting
    If you are looking to keep close tolerances (like +/- 0.010" and tighter) and you don't want rounding on the top edge, proper stand-off distance is important. The closer you can cut to the material the faster you can cut and the straighter your cuts will be because you will loose less of the stream's energy to the atmosphere. Several waterjet manufacturers now offer height control. I work for Bystronic and we have been using height control on our waterjets since we first started building them in 1988.
    Usually some form of abrasive nozzle protection is integrated in with the height control to reduce the possibility of nozzle breaks.
  1. ceramic nozzle body for bystronic laser cutting machine
    By lordof in forum Want To Buy...Need help!
    Last Post: 08-17-2011, 07:17 PM
  2. ceramic nozzle body for bystronic laser cutting machine
    By lordof in forum News Announcements
    Last Post: 05-18-2008, 03:59 PM
  3. ceramic nozzle body for bystronic laser cutting machine
    By lordof in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2008, 10:38 AM
  4. Waterjet mixing tubes (nozzle)
    By Tommy2Times in forum Waterjet General Topics
    Last Post: 03-07-2008, 04:49 AM
  5. 5/8 Ballscrew Critical speed
    By LazyMan in forum DIY CNC Router Table Machines
    Last Post: 02-13-2008, 01:06 PM
