Hi There,
I'm just creating simple 2D stuff, but I would like to take the edge off the perimeter (essentially chamfer) on a piece I'm cutting out.
What I'm wanting to do is use a ball nose endmill & run it around this said perimeter (prior to running the standard full through the material cut on the same perimeter), but without any compensation ...in other words I just want the cutting tool to run around the actual perimeter line as opposed to a small offest (which Mastercam typically allows/compensates for the cutter's radius when forming the toolpath)
A seemingly simple requirement, but I can't establish a way to do this (when I select 'compensation 'off' in paramaters, I don't see any toolpath afterwards!) - please give me a pointer!
