603,975 active members*
3,298 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > No U-axis input possible in Work offset
Results 1 to 5 of 5
    May 2006
    99
    Hi all,
    I have a KiwA with 4th axis. But can't input anything in the U offset ( G54 to G59) . And why is it a "U" instead of a "A" axis.
    I keep having to go to parameter setting to input the U coordinates and I' am kind of getting sick of it. Cause someday something might just go wrong in parameter while inputting without paying 100% attention.
    I guess it's just a parameter setting. But don't know what to change. I would like to change the "U" to an "A" as well if possible. But thats not the big deal.
    The WORK OFFSET is far more important.
    Can anyone help me with this?
    Thanks again!
    Jun 2008
    1511
    First what kind of control are you using? What function are you using to set the work coordinates the G10? Is the U-axis a position of the spindle or a position of a rotary table?
    The parameters for the G54-G59 can be set by programming the parameter. So if you can go to the parameter settings and change the U-axis parameter you should be able to change it via program. Now I am not 100% about you control but if you were using G54 as an example:
    G54X=#5221
    G54Y=#5222
    G54Z=#5223
    G54U=#5224—if this is next in line of your work coordinates. If this is the parameter for the U-axis you should be able to put right in your program #5224=10( or what every you want).
    If you have a O series control then it is parameters 2501,2502,2503,2504
    Stevo
    May 2006
    99
    I am using Fanuc OM-C.
    I always put in the work coordinates in the Offset registry ( G54 till G59)
    I can put in the X,Y and Z but the U is there but can't input anything.
    I input the U coordinates in parameter 758 for G54, 762 for G55, 766 for G56 and so on.
    Jun 2008
    1511
    So what is the U-axis for??
    I looked through the OM manual and I could not find anything that would lock or not allow you to change the U-axis in the work coordinate page. What you will probably have to do is to write this into the program. Can you change it via G10? If you program a G10L2P2U1. This should change the U in the work coordinate page under G55 to 1. P1=G54, P2=G55, P3=G56, P4=G57, P5=G58, P6=G59. If you do not have the G10 option then you will have to program the change by #2524=1.
    I am not very familiar with the O series control but this is the data that I have that should work.
    #2501-#2523 Fixture offsets (for O series)
    Offset....X.........Y........Z
    G54...#2501..#2502..#2503
    G55...#2521..#2522..#2523
    G56...#2541..#2542..#2543
    G57...#2561..#2562..#2563
    G58...#2581..#2582..#2583
    G59...#2601..#2602..#2603
    Now I am not 100% but the U-axis for the work coordinates should be:
    G54=#2504
    G55=#2524
    G56=#2544
    G57=#2564
    G58=#2584
    G59=#2604
    I will try to do more digging to see if I can’t find something on setting the “U” in the work coordinate page.
    (Edit)..Does it give you an alarm or error when you try to change it in the work coordinate page?
    Stevo
    May 2006
    99
    Doesn't give me any alarm. I'am not even able to type the U on the keyboard.
    I'll have to try the G10. Not even known with G10 on mill.
    The "U" is the 4th axis. Normally it should be a "A" axis cause it's laying in the X -axis.
    But we bought it as a U.
    Thanks again!
  1. meldas-m0 Cannot input G54 offset numbers
    By Place2809 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-22-2009, 10:29 PM
  2. 6M-B 4th & 5th axis work offset changes
    By R-Bob in forum Fanuc
    Last Post: 10-08-2008, 06:33 PM
  3. Running one work offset.
    By ltmquik in forum Haas Mills
    Last Post: 09-07-2007, 07:02 PM
  4. 6M Z offset input
    By TR MFG in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-05-2005, 04:24 PM
  5. Tool offset input
    By Mircea in forum DNC Problems and Solutions
    Last Post: 05-29-2004, 12:16 AM
