I'm having some problems with a Gecko driver, and in the process of horsing around inside my controller I may have caused more problems.
Right now, I need to know how to troubleshoot Mach 3 outputs to be sure that my control box is getting step and direction voltages at the control box input. As I look at the settings in Mach 3, I don't think they are changed and they seem to be correct. Mach seems to be running the X axis when I jog, showing motion on the DROs. But the controller won't move the motors.
In the controller, the fuses are OK, and the Geckos have power LEDs on. The Y and Z axis are OK. Just the X axis is not working.
If I can determine that Mach3 is sending the correct voltages, I can start looking in the control box.
Thanks for any help.
Wayne C
