587,997 active members*
2,192 visitors online*
Thread: Noise
Results 1 to 4 of 4
    Dec 2010
    Noise
    G540
    Nema 23's 3.5A
    48V PSU
    I have a lot of noise when the motors are stationary. I have wired them as recommended in the G540 manual with pins 1 -5 with 3.5K resistors and pins 2,3,4 to the shielding.
    I have tried it with everything off around the machine including the computer itself and the noise is still there. Do I need to ground the motors themselves to the shielding?
    Andrew
    Apr 2007
    8082
    Have you followed the G540 motor tuning instructions from Gecko's site? There is a small potentiometer inside a hole in the cover for each of the four motor outputs.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Dec 2010
    Quote Originally Posted by CarveOne View Post
    CarveOne
    Yep
    Apr 2007
    8082
    I have a new 4 axis G540 kit from cncrouterparts on the bench with just the short motor leads plugged directly into the G540. It makes no noticeable noise when powered and not moving, just when the motors are moving. I haven't made any cables for it yet, and haven't done the tuning procedure.
    CarveOne
    CarveOne
  1. Noise
    By Jdtray in forum Gecko Drives
    Last Post: 09-26-2010, 12:03 AM
  2. keep the noise down!
    By SIMONSIGNS in forum CNC Machine Related Electronics
    Last Post: 12-04-2008, 06:42 PM
  3. So Much Noise
    By camcam in forum Open Source CNC Machine Designs
    Last Post: 04-15-2008, 03:39 PM
  4. Noise
    By keys in forum DIY CNC Router Table Machines
    Last Post: 04-25-2003, 07:47 PM
