588,385 active members*
5,457 visitors online*
    May 2003
    267
    noise from motor
    I am trying to build my first CNC machine. I am concerned with the noise of the router motor. I am considering using an air spindle. I believe this spindle must use some sort of air compressor. Does anyone know if the air spindle with air compressor is quiter than a router motor? Where can I find air spindles and what are the price ranges for them.
    I want to avoid having to build an outdoor shed just for my 4' x 3' cnc.
    Thanks,
    Apr 2003
    97
    http://pico-systems.com/Machining.html
    Seems to be the guy to ask. He has one operating on a CNC machine he built. His pics of the spindle are under Projects - last selection.
    Worry about success, failure takes care of itself.
    Mar 2003
    2139
    Air motors (die grinders) are just as loud as a router. They are not efficient. It takes a two horse power compressor to get 1/4 hp at the die grinder. Stick with a router.
    Eric
    I wish it wouldn't crash.
  1. Noise in Bridgeport 2J head (audio file included)
    By daytrader in forum Bridgeport / Hardinge Mills
    Last Post: 08-03-2016, 07:03 PM
  2. Motor Humming Noise?
    By Dman in forum Hobbycnc (Products)
    Last Post: 11-10-2008, 01:03 AM
  3. Replies: 5
    Last Post: 08-31-2004, 02:16 PM
  4. Which stepper motor should I buy
    By Graham S in forum FAQ of DIY CNC Machine Building
    Last Post: 08-27-2004, 11:58 AM
  5. Servo's - oversupplying voltage for speed
    By AJ_Mac2001 in forum CNC Machine Related Electronics
    Last Post: 01-18-2004, 05:32 AM
