603,979 active members*
3,552 visitors online*
    Sep 2005
    4
    Non working spindle rpm indicator
    Can anyone help me with my non working spindle rpm indicator (dro39), I am using a G100 with latest plugin and Mach3 v3.039.
    I have a hall effect sensor going to input 1 on g100 and the input led is flashing as it should,
    the index led on the diagnostic screen blinks every now and then.
    I have index enabled in ports and pins and have tried active low and high,
    just finished a full reload of mach3 hoping it may solve the problem, but no change.
    Sven
    Mar 2003
    35494
    Are you sure mach3 supports it when using the G100? I don't believe it supports threading, so it may not support the index pulse either.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2005
    4
    Hi Gerry
    Who knows what mach 3 supports with g100, info is a bit hard to get, do any other g100 users out there have rpm working?.
    I wonder if I could sneak the index signal in through the printer port and bypass g100?
    sven
  1. Spindle Braking Not Working
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 01-26-2008, 11:15 PM
  2. Dial indicator
    By hkrok in forum News Announcements
    Last Post: 08-17-2007, 01:49 AM
  3. problem with BP series 1 spindle not working
    By zoqdi in forum Bridgeport / Hardinge Mills
    Last Post: 02-06-2007, 10:04 PM
  4. Z axis zero indicator switch
    By cnc rider in forum Mach Mill
    Last Post: 09-29-2006, 05:00 AM
  5. what does dial indicator use to measure?
    By cnc2k in forum MetalWork Discussion
    Last Post: 07-16-2005, 01:20 PM
