Hi everybody,
I'm relativley new to the trade (six months) and I have a question regarding dowels and how to locate them parallel. In this case the dowels are fit into an aluminum tool (car seat mold to be exact) for re-machining and my question is this:
Is it incorrect to bring a dial indicator (in a vertical spindle of a CNC mill) to an approximate position in front of the dowel, then hand turn the spindle until it reads zero? How can you be sure that the arc of the probe isn't off centre, thus giving you a bad reading? I've seen one of the other "more experienced" fellows do this and it doesn't seem right.
IMO you should locate the dowel centre by using the probe of the indicator by indicatind each side on the X axis, then the Y, THEN zero the Y and jog to the other dowel and verify. Am I missing something here, or am I a shmuck?
Thanks guys....
