603,980 active members*
2,245 visitors online*
    Question NOOB Help needed
    Hi -
    I am making my first stepper motor controller. Need some help reading the documentation for the chip I am using. (MC3479)
    What is VD & VM?
    Please check out my CNC blog
    http://cncinside.com
    Nov 2005
    83
    It is explained on page 4 of the documentation.
    Vm is the power supply pin for the chip and the steppers. It takes +7.2 to +16.5 vdc.
    Vd is used for a clamping diode between pins 1 and 16.
    Any time you turn power on then off with a coil in a circuit (the motors), you will get back voltage returned from the coil. This voltage can rise pretty high and spike components in that circuit if not dealt with.
    If you look at figure 12 on page 9 you can see the voltage will be returned to the supply + side.
    Thanks -
    Right now I am putting things together on a breadboard and seeing what I can do.
  1. yet another noob
    By mastermoparman in forum Community Club House
    Last Post: 09-18-2006, 07:22 AM
  2. yet another noob
    By mastermoparman in forum Uncategorised MetalWorking Machines
    Last Post: 09-15-2006, 12:24 PM
  3. NooB Needs a little Help
    By js11110 in forum DIY CNC Router Table Machines
    Last Post: 03-21-2006, 12:41 AM
  4. I know, I'm a noob...
    By WilliamD in forum CNC Machine Related Electronics
    Last Post: 10-08-2005, 02:19 AM
  5. Noob Alert or Run while you still can!
    By anoah in forum DIY CNC Router Table Machines
    Last Post: 05-10-2003, 02:15 PM
