588,064 active members*
5,052 visitors online*
    Sep 2005
    249
    Noob software question...
    I have autocad 2000, and am able to draw my woodworking stuff in 2D and my 3D needs. I have mach3 to run the controller and CNC. Do I need anything else? Should I be able to just export the DXF file from Autocad to mach3 and it translates it? Is there anything I'm missing? I'm sure I can do that, but is there a better way? Thanks for any advice!
    Apr 2004
    90
    Take a look at www.deskam.com. I have had good success with this program. You can open up dxf's and generate good roughing and finishing passes. Plus the CAM output is customizable. It has a free trial period.
    Brian
    Mar 2003
    35538
    Quote Originally Posted by WilliamD
    Mach3 can read 2D .dxf's, but is limited in what you can do. It may be perfectly fine for your needs. A great low cost option would be Sheetcam. www.sheetcam.com If you want to do 3D carving, check out MeshCAM. www.meshcam.com
    I don't think it will work in ACAD 2000, but I wrote a macro that exports g-code from within AutoCAD and does a lot more than Mach3 will. It works in 2002 and newer, but it may work in 2000. You can try it and see. http://home.comcast.net/~cncwoodwork.../AC2GCv039.zip
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
