588,380 active members*
5,202 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Not loading program made in CAM software.
    Jun 2011
    22
    Hey guys I'm trying to help out a fellow shop owner I know with a part he asked for me to program for him.
    I wrote the code and it will verify at the Milltronics control but when I try to load it as suggested by a Milltronics tech I get an "error code 302" when I press the load button.
    What is the extension format of the post?
    Oct 2008
    427
    You need to re-name the program to O####, the letter O with 4 number digits, change the MISC parameter Full DOS Filenames to yes, or press Shift+D on a keyboard to toggle to Full DOS Filenames on to allow the control to 'see' the files on your disk.
    Jun 2011
    22
    Thanks for the reply you were correct Im sorry for the late response I didn't see this until after talking to one of the guys at milltronics.
    Alslo had to add code to cancel out the trig help function for the machine to pick up my cutter comped moves.
  1. Loading NC program
    By data-matique in forum HURCO
    Last Post: 06-17-2018, 03:43 AM
  2. LOADING PROGRAM
    By SELECT in forum SIEMENS -> GENERAL
    Last Post: 07-08-2010, 05:48 PM
  3. Need help loading program from usb
    By hankster in forum Haas Mills
    Last Post: 07-29-2009, 11:08 PM
  4. loading program
    By SELECT in forum Haas Mills
    Last Post: 08-14-2008, 12:31 PM
  5. up loading a cnc program
    By fjd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-06-2003, 12:34 AM
