603,872 active members*
3,343 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Not receiving signal from sensor
    Apr 2014
    Our VF-1 is not seeing the signal from the Y hard stop switch. The signal makes it to the board but we cant see it being made on the control. Any help would help.
    May 2012
    67
    Re: Not receiving signal from sensor
    What happens when you zero return the Y axis?
    Depending on the software your control might not show when the home switch is tripped.
    Thank you,
    Phil
  1. Replies: 2
    Last Post: 05-10-2012, 02:17 PM
  2. sending and receiving files
    By ashro in forum OneCNC
    Last Post: 02-08-2011, 09:04 AM
  3. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  4. problem in receiving data
    By paulstrife88 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-10-2008, 09:28 PM
