603,336 active members*
4,041 visitors online*
Results 1 to 5 of 5
    Jan 2009
    4
    Not recognized keyboard
    i had deleted the ram of my fanuc controller series OT and now my keyboard is not working correctly. It's strange because when i am in the offset mode the keyboard is enable to introduce data this happen also in program mode but in this case the keyboard works like the compact version where the letters and the numbers are in the same key. Now, when i want to do the same action to set parameters, the keyboard doesn't work. A thecnician told me that i can't introduce parameter because the system initialize in EDIT mode and should be in MDI mode, but we can change it. Another solution was change the keyboard to the compact version (the daewo 8HC has a extended keyboard that includes letters) but we are still looking for it. If you have any idea about it, i'll be pleasured.
    Regards
    Parameter 38 bit 3 = 1 (full keypad) = 0 (standard keypad)
    To reload parameters.
    Push the E stop button in.
    Power up holding in "Reset" and "Delete"push buttons.
    Load all 900 series parameters.
    Power off then back on.
    Reload the rest of the parameters and diagnostics
    Jan 2009
    4
    Thanks cncdiag,
    The parameter 38 bit 3 is equal to 0. We could found the standard keypad and it is working however i can't load parameters yet. I'm following these steps:
    0. Turn on the system
    1. Parameters push button on (DGNOS/PARAM)
    2. Number push button on (No./L/Q/P) and insert the parameter number
    3. (INPUT) push button on
    4. No. push button on again and insert the bits array
    But when i try to load the bits array (step 4) the keypad doesn't work. Do you know any idea about it? That's the procedure, right?
    Press E stop in.
    Set PWE = 1
    MDI mode
    Parameter page, reload parameters
    Jan 2009
    117
    Pull out all the plugs mounted on the I/O pcb.
    Mode will become MDI with EMERCENCY STOP condition.
    You can re-insert the plugs after you have reloaded the 900 parameters which you should re-input first manually.
  1. PBC Linear Now a Recognized AHTD Manufacturer
    By Pacific Bearing in forum News Announcements
    Last Post: 01-13-2009, 10:10 PM
  2. i hate this keyboard
    By dertsap in forum Canadian Club House
    Last Post: 10-27-2008, 02:09 PM
  3. keyboard,,
    By billwe in forum Haas Mills
    Last Post: 04-29-2008, 02:57 AM
  4. Keyboard problem
    By BeliVolk in forum CNC Machine Related Electronics
    Last Post: 07-10-2007, 07:00 PM
  5. keyboard jog
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-09-2004, 03:17 AM
