Ok I know this is not the right place but everyone is quick to reply in this forum. Here goes I am wanting to do relief carvings I am currently using Adobe illustrator and photoshop along with meshcam. However meshcam is great but I would like to be able to pick and choose what areas are cut and at what stepover (the problem I have is meshcam covers the whole piece which works but really slows me down when I only want certain areas carved with alarge stepover and others with a small stepover I want to be able to say this part cut at blah and this sectiomn cut at blah so when I rough cut and remove everything cut through then when I run a final it wont go back over that area since there is nothing there) So how do I do this I have autocad 2006, photoshop,adobe illustrator, meshcam, and I have access to Mastercam9 and X but I dont know how to use these programs what programs do you guys recommend to do what I want to do? I will buy it if its not one I have Oh and I will be using Mach2 or3 to run the machine.
Thank You all
