603,960 active members*
2,209 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software > Notebook pcmia parallel port card output pin voltages are not steady
Results 1 to 15 of 15
    Jul 2007
    189
    I am running XP pro on a gateway notebook computer which is running mach3 and mach3 is controlling my 3D printer with 4 stepper motors
    The motors and 3D printer all work fine
    I have the notebook stripped down to bare bones and have not experienced any pulsing problems so far.
    What I want to do now is use M7 and M9 to turn on and off a relay board that turns off 12 volts to the hot end temp control board.
    So basically, a relay board will turn off the 12 volts going to the hot end after a job finishes and shut down the extruder
    I have a relay board that works fine on my CNC machine desktop computer running xp pro.
    The relay board uses a mosfet to control the relay coil
    All it needs is a high/low voltage to trigger the mosfet/relay coil.
    On my desktop cnc machine I can read a steady 5 volts on the parallel port output pin when I enter M7 in mach3
    On the notebook I get a wavering voltage figure that is not steady at all
    It wavers between 2.2 volts and back down, then up, and down, etc.
    This is not enough to trigger the mosfet/relay coil
    It's a plug in pcmia parallel port card and it works fine for all 4 motors, but there does not seem to be enough steady DC voltage to trigger the mosfet/relay coil
    I am scratching my head as to why the pcmia card is good enough to operate all the steppers but I can't get a decent hi-lo voltage on an output pin
    Output #2 LED does light up in Mach3 when I enter M7 and it goes out when I enter M9
    Output #2 is assigned to pin #1 on my breakout board but I tried pin 14 also with the same results.
    So how can a pcmia parallel port card work fine in Mach3 to run 4 motors but not be able to supply a steady DC voltage on an output pin?
    thanks for any help
    Jun 2007
    3738
    Maybe it needs a pullup resistor. Say 10K. It might only be pulling down.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jul 2007
    189
    I tried using a 4.7k and a 10k pullup resistor across the ground and output pin
    Still no good, the output pin voltage wavers all over the place
    I have tried all 4 remaining unused output pins which are 1, 14,16 and 17
    Same results on all four pins when assigned to output #2 in Mach3
    M7 lights up the output #2 LED in mach 3
    If I touch my finger to the gate on the 2N7000 FET, the relay coil will engage
    M9 shuts off the relay coil just fine
    The whole problem is the wavering voltage coming from the pcmia card does not seems to be steady or strong enough to trigger the gate on the 2N7000 FET
    this is the circuit I am using and it has always worked fine on my Desktop XP CNC machine
    Jun 2007
    3738
    Try this. The mosfet looks like it needs more drive voltage.
    Us a common base NPN transistor circuit.
    Base of transistor junction of 2 10k resistors.
    top resistor goes to 5v.
    bottom resistor goes to 0v.
    That will give 2.5v on the base.
    Connect port output to the emitter.
    Connect the collector to the gate of mosfet, with a 10K pullup.
    You might need to make the 2.5 higher or lower by changing value of one of the base resistors.
    This formum is shooting blanks again. Nearly did a double post because it appeared not to complete.
    Jul 2007
    189
    That sounds good but then I have to find +5 volts from somewhere
    My 3D printer power supply is 12 volts
    The only 5 volts I can think of is the USB port on the notebook
    Jun 2007
    3738
    A 10K from 12v and a 2.7K to 0v will give you 2.55v
    Bottom resistor. A.
    Top resistor B.
    12 x (A/(A+B)) = 2.55v
    Jul 2007
    189
    Ok, thanks, a voltage divider
    I'll see if I have a NPN trans laying around to experiment with
    Jul 2007
    189
    Ok your suggestion of adding a NPN transistor to the gate of the FET worked great
    The Relay now clicks on and off with M7 and M9
    Here's the Relay circuit I am using
    Attachment 203352
    Jun 2007
    3738
    EL34,
    That was nice to draw a circuit for all to see.
    Call 2K7 the A and 10K, B.
    We aim for 2.5v at the junction so other than 12v requires changes in the value(s).
    See post #6 above for the clues on how to calculate.
    You may need to change the values of the A resistor to get off the shelf value for B.
    As long as the ratio is correct, the value of A and B could be 27K and 100K.
    Jul 2007
    189
    My 7amp 12volt Dc power supply is a bit higher than 12 volts
    I may have to adjust the values a bit because I have closer to 3 volts at the junction of the voltage divider
    Jun 2007
    3738
    Use a 12K instead of a 10K. That should fix it.
    If it works, measure how close the margin is to be sure.
    Jul 2007
    189
    A 2.2k for resistor A ended up working perfectly
    I have 2.51 volts at the junction of the voltage divider
    So I have a 10k at the top of the voltage divider and a 2.2k at the bottom
    I forgot to add this is my test and it still worked
    So a 10K from the junction of the FET gate & NPN collector down to ground, correct?
    Here's shot of the relay board I cut on my CNC this morning
    Jun 2007
    3738
    What voltage are switching on the output of the relay?
    Jul 2007
    189
    I am switching 12 volts
    The load is around 3 amps
    I am turning off the 40 watt heater cartridge to the extruder on my 3D printer
    When the print job ends, Mach3 issues a M9
    Jun 2007
    3738
    That's fine.
    Just checking because if you were switching high voltage you would need 3mm clearance between the relay contacts and 6mm between relay contacts and the PC side of the circuit.
    This is for safety, and is creepage distance.
    Have a look at layout on the bottom of old switchmode power supply to see typical isolation used.
    Often there are slots in the PCB where the distance of 6-8mm can't be achieved.
  1. Parallel port pci card
    By Dylwad in forum PlasmaCam
    Last Post: 08-07-2013, 02:15 PM
  2. Parallel port add-in card.
    By Drools in forum Gecko Drives
    Last Post: 06-27-2012, 06:40 PM
  3. Which PCI parallel port card?
    By bead in forum CNC Machine Related Electronics
    Last Post: 07-03-2010, 07:32 PM
  4. Run From PCMIA card
    By Bluesman in forum Fanuc
    Last Post: 08-16-2008, 03:49 PM
  5. No parallel port on my dell notebook
    By cyrkle in forum Computers / Desktops / Networking
    Last Post: 02-21-2006, 02:34 AM
