603,347 active members*
2,877 visitors online*
Results 1 to 11 of 11
    Post Notepad++ gcode plugin
    Hi all !
    A while ago I posted here about my project => https://www.cnczone.com/forums/cnc-e...-software.html.
    Lately I have been working on implementing some of the features within a Notepad++ plugin.
    I use Notepad++ a lot to edit various kind of script and files, and I think it could be useful to be able to plot some gcode inside.
    So here it is, the notepad++ gcode simulation plugin: https://github.com/NCalu/NCneticNpp
    The plugin has been tested only by me so use at your own risk...
    Any feedbacks, positive or negative are welcome.
    Re: Notepad++ gcode plugin
    works like a charm and plots large files quickly , nice plugin thanks . I've got backplotters and editors but I find myself using notepad++ a lot . Mostly due to it's macro functions which allow me to do mass edits to my programs with a single mouse click . The backpoltter will be a big help .
    I downloaded ncnetics a while back and only played with it a few times but I like it . Are you still developing that or have you done what you need to do with it
    Thanks, glad the plugin works somewhere else than on my computer .
    I consider that a good start.
    I am still developing NCnetic, I use it for my work.
    What backplotters/editors do you use ?
    I use ncplot which I like overall with the exception of a couple quirks
    Jun 2015
    4189
    hy kalu i just looked a bit over NCnetic
    i am interested in solid interference algorithms, intersection between 2 cilinders, etc
    i would like to talk more with you; do you use wathasp, telegram, something ? kindly
    Nov 2012
    158
    Thank you, this is a very nice to have tool in N++. If anything, I'd note that it's a bit awkward to tell which file you're looking at plotted if you have multiple ones open in N++. The plotted file being colored/styled does indicate which one it is, but that's the only way I found to tell, and with many files open that could get tedious.
    The other small drawback I see is that there's no way to combine multiple files into a single plot - but that would probably be a lot of work to do anything about. I usually split various phases / tools of machining into separate files for my GRBL-driven mini desktop mill, which is why being able to load and plot all of them together in NC Corrector is something I use a lot. But that's just icing on the cake...
    Other viewers I use are Camotics, NCSim and the CNCEdit Basic CNC Viewer. There's always something one of them does better and when in doubt, I get to compare "second opinions" - but in the end I'm just a hobby user with unsophisticated needs...
    Quote Originally Posted by deadlykitten View Post
    I sent you a PM
    Quote Originally Posted by blinkenlight View Post
    I understand, if you click on the toolpath it should jump back to the file plotted.
    Do you have some other user friendly solutions in mind ?
    I think it can be done by combining the various files together in one and then plot them in NCnetic.
    In the old versions of NCnetic this was an option, but it was messy so I prefer not to deal with that anymore
    Nov 2012
    158
    Quote Originally Posted by Kalu_9891 View Post
    Neat, I haven't noticed that. I had nothing fancy in mind just maybe adding the plotted file's name and/or path to the plot window title bar, that currently only says "NCnetic". Possibly marking the opened file's tab somehow, if there's some easy way for plugins to do that sort of thing...
    Good idea !
    I will check if I can implement that
    Jul 2024
    I've been using Notepad++ for a while. I'll definitely give this integrated plugin a try and let you know how it goes.
    Jul 2024
    Quote Originally Posted by Nepheway View Post
    It's great that you're open to feedback, both positive and negative. That's how projects like these get better and better.By the way, if you need a platform to share updates or collect anonymous feedback, you might want to check out https://notesonline.com/ . It's a handy service for creating and sharing notes without needing to log in, which can make collaboration easier.
  1. Notepad++ plugin
    By PlanetCNC in forum PlanetCNC
    Last Post: 03-14-2022, 12:21 PM
  2. Gcode Unit Converter Plugin
    By Dan911 in forum UCCNC Control Software
    Last Post: 05-29-2018, 12:29 PM
  3. Notepad++ Gcode Lexer
    By safecnc in forum OpenSource Software
    Last Post: 05-12-2016, 04:04 PM
  4. New PlugIn Jog to Gcode (JCode)
    By Barker806 in forum Mach Software (ArtSoft software)
    Last Post: 07-14-2007, 06:17 AM
  5. Gcode verify autocad plugin
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 10-31-2003, 06:22 PM
