I'm using 1/8in Lexan. The enclosure is made of 1010 size extruded AL (BOM Attached). The slots in the 1010 are 0.25in which does not leave room for the rubber gasket material. I wanted the enclosure to be coolant proof, so I reduced the Lexan to 1/8in and added rubber gasket material on both sides. Lexan will only be used on the front portion as it's pretty pricey. The remainder will be white 1/8in corrugated plastic sheet. Home depot sells it online for a fraction of what everyone else does Link Here. You get 10 sheets of 4' x 8' for $110. It will last me a long time......Don't tell anyone, it's one of my secret stashes :cheers:. 1/8in plywood could also be used for the enclosure walls if you really wanted to be frugal.
