587,600 active members*
4,446 visitors online*
Thread: Novusun NVEM
    Jan 2007
    626
    Novusun NVEM
    A friend recently bought one of these and we have been trying to get it working ever since.......
    I have tried everything I can think of to get it to communicate with a PC and read dozens of posts about people having the same problem.
    The most obivious things are:
    Different pluggins ( including the one for the later EC500 )
    Multiple IP addresses ( always used the Netmask )
    Different Ethernet cables
    With and without a Router ( removed the IP when testing the router.
    Disabled the firewall
    Ran Winfdoes Diagnostics. Best clue I got was 'IP address was not configured correctly" No idea why, or how.
    Most of the tales of woe were from around 2017, some a little later.
    Best I get is 'connected' led and Sent packets, but No recieved traffic from Novusun.
    I know the answer already, but here goes:
    Before I hurl this thing against a brick wall, Has anything significantly changed that will now allow this to now work properly in 2023?
    We are looking at getting a UC300ETH to replace it.
    Steve
    Nov 2013
    4537
    Re: Novusun NVEM
    I'm sorry to say but that is about what you can expect from Novosun. You'll get no help from the Mach forum either, Novosun are on the permanently banned list for peddling
    pirate copies of Mach.
    That is a very reasonable solution. I myself use an Ethernet SmoothStepper ($195USD) and Mach4 and have done for eight years. The ESS will run either Mach3 or Mach4, but Mach4
    is light years ahead....if this is a new build then mach4 is recommended.
    You want, in fact need, a motion controller that has support. Novosun is not it. There are entirely enough challenges to CNC without the motion control giving you grief.
    Craig
    Jan 2007
    626
    Re: Novusun NVEM
    Thanks Craig.
    Yes, I use a ESS and MB3 BOB for cncroom. Very happy with it.
    This person is an old, and a newbie pensioner so funds are tight.
    He also wants to stay with Mach3 as he has a license for it and is familiar with it.
    He is retrofitting a chinese 6040 Mill, so he has his work cut out. I live 4000km away from him so its difficult to help.
    I stressed the need for 'support' at the start but funds overrid that, I'm afraid.
    Hopefully he will have more luck this time....
    Steve
  1. Help with Novusun NVEM control card
    By RODCNC1147 in forum Controller Cards
    Last Post: 02-22-2024, 11:59 AM
  2. ethernet NVEM v2 Novusun mach3 board "device not ready" ?
    By santydofus2014 in forum Hobbycnc (Products)
    Last Post: 06-25-2022, 12:53 PM
  3. Replies: 2
    Last Post: 12-12-2020, 02:16 PM
  4. Help with Novusun NVEM control card
    By prapto in forum Uncategorised CAM Discussion
    Last Post: 02-18-2019, 05:31 AM
  5. Help with Novusun NVEM USB control card
    By morg769 in forum Controller Cards
    Last Post: 11-13-2018, 11:19 AM
