588,209 active members*
4,342 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > NPT Threadmilling
    Oct 2006
    13
    NPT Threadmilling
    Tonight at work I was playing with the Tapered Thread plugin. At the moment I'm using a generic incrimental NPT sub program to do my NPT threadmilling, but I'd really like to do it straight in Gibbs. So far I've played with the 3/8-18 settings that it already had in the Plugin. I created the geometry which ended up being a little helix over the point I want to threadmill. If I can remember correctly the helix went about -.408 deep. Now correct me if I'm wrong, but to try it out I ran a contour on that geometry. I set the depth at zero thinking that the depth would automatically be picked up by the geometry's depth, but when I looked at the code that it posted out, it basically milled above my part (obviously the zero depth was wrong). Any suggestions? I also just used the threadmill in their tool list and filled in the info for it as I normally do for my NPT spreadsheet. Since it's a single thread cutter, it runs the entire length of the helix which would take a pretty long time.
    Apr 2004
    353
    You did everything fine but I think your tool might not be setup correctly. Make sure the length of the 60 deg cutting edge is set properly. Everything else looks ok.
  1. Threadmilling on a V2XT
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 05-16-2007, 03:06 PM
  2. Single point vs. multipoint threadmilling
    By RoboElvis in forum MetalWork Discussion
    Last Post: 03-27-2007, 08:11 PM
  3. Threadmilling Fanuc 6M-B
    By mtglaser in forum G-Code Programing
    Last Post: 10-07-2006, 04:12 PM
  4. Macro B Threadmilling on C-axis.
    By M-man in forum Fanuc
    Last Post: 09-22-2006, 07:29 PM
