567,614 active members*
2,603 visitors online*
Thread: NUM 1060
Results 1 to 14 of 14
    Feb 2008
    3
    Question NUM 1060
    Hallo to all!
    Recently I came up with a Num 1060 controller but it seems not to have a SPS program. It is a the parameter program for the machine processor. So the processor can't work. Does anybody has a similar machine so to unload a parameter program?
    Thank you very much!
    E-mail: sforoulis@gmail.com
    Feb 2008
    3
    NUM 1060 Tools for Software Backup
    Hallo again!
    I want to share with the forum the tools of making a backup from a NUM 1060 PLC controller.
    Please post here all the files concerning NUM 1060 so as to make a thread for this machine to have as a reference in our potential problems
    Thank you!
    Stelios_25
    Attached Files Attached Files
    Jan 2008
    Hi, I have the NUM1040 controler and am having trouble connecting to it via serial so ill give these Apps/Docs ago and see if they shed any light on the problem.
    Many thanks for sharing.
    Oct 2009
    3
    Nipper Hello, I work with a num 1060 and know all the possibilities of connection, which is used by you? Unitelway?
    Apr 2010
    22
    Hi. I can see that there are tools for backing up info from NUM 1060. I also need those tools for my NUM 1040 cause until now i lost all connfiguration from the machine 3 times due to battery dead and loss of memory Each time the technical assistance comes it takes about 1000 euros to restore it ( with all the expenses related to it ). On these days that takes my founds away Can anyone help please.
    Thanks in advance
    By the way, anyone knows whats the cost af a complete NUM compact panel includind 8.4" LCD display ? they charged 3800 euros for it. The display monitor was complete white. Had a friend that told me that it could be just the LCD display. Can i connect one regular CRT monitor to the NUm panel ??
    Sorry guys but im desperated with this dont know if i can post it here ...
    Junior Member
    Feb 2015
    88
    Re: NUM 1060
    Hi
    does any one have a software can read the ladder file of NUM1040?
    sting
    Re: NUM 1060
    Hi confletaismar,
    I have bought a second hand num 1060 machine. Because, Its battery is dead, we have change it. Than we upload the plc firmware from backup. Now the machine is up but not working. I think this is because of the initial parameters of referance etc. Do you know how can we load them. There are obj files in the backup folder on the computer which we bought it with the CNC. Due to, I don't know what to do with this file I prefer not to thouch them till know how to handle.
    Best Regards,
    Mustafa MUTLU
    Jan 2020
    Re: NUM 1060 Tools for Software Backup
    Hello,
    Thank you very much for sharing these tools, i have a SOMAB Transmab 400 / NUM 1062 T, it remained a long time with a descharged battery so all NC data were lost, can please share with us the backup files ?
    Thank you !
    Gafsi
    Jan 2021
    Re: NUM 1060
    Hello. I have a problem with num1060, namely the memory backup battery has died and all machine files have been deleted. I have something there but from what I found out I probably miss the PLC file. Can any of you help me?
    Oct 2021
    Re: NUM 1060
    Quote Originally Posted by adamus View Post
    Hello,
    this is all the file restore of my SOMAB Transmab 400 / NUM 1062 .
    Aug 2022
    4
    Quote Originally Posted by stelios_25 View Post
    Hallo again!
    Thank you!
    Stelios_25
    Does anybody can share please the tools and/or documentation for making a backup / restore ...
    us_117_10xx_Mem_Map.pdf
    us_138_10xx_CNCDisk_Backup.pdf
    us_139_NUMBackup_DiscNT.pdf
    us_141_NUMBackUpAlarms.pdf
    us_145_10XXBatteryChange.pdf
    us_148_Power_CNC_Battery.pdf
    etc (if you have more pdfs please share for future reference)
    Re: NUM 1060
    I have a Schneider Engineering AG paper cutting machine.
    It works with a NUM 1062 controller.
    Because of a dead battery the machine lost its settings.
    Does anyone have the right settings?
    Sep 2021
    5
    Re: NUM 1060
    I have a Z.Bavelloni Kam250 works with NUM 1040 controller.
    Feb 2023
    Re: NUM 1060
    Dear friend, I'm new user in this forum, our BOSS bought a old machine with cnc NUM1060, I worked in FANUC and Heidenhain cnc but I don't know Num programming.
    Please can you shere me some example of program?
  1. Crown 1060 trouble
    By machine_51 in forum Okuma
    Last Post: 08-19-2011, 08:25 PM
  2. newbie ,need help on Num 1060
    By icetak in forum Controller Cards
    Last Post: 07-22-2011, 10:00 PM
  3. AA 1060 (99.6% Al)
    By melt_fire in forum General Material Machining Solutions
    Last Post: 03-25-2009, 10:49 AM
  4. Tree VMC 1060
    By StahlMachine in forum Tree
    Last Post: 12-27-2007, 03:55 PM
  5. num 1060 or the like
    By sc_crasher in forum Fanuc
    Last Post: 01-12-2006, 02:11 AM
