588,197 active members*
4,580 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Numbering 88hs tools
Results 1 to 5 of 5
    Aug 2009
    15
    I am new to fadal. I have a '94 4020ht with the 88hs control. My question is, do you have to name your tools from 1-20? I work from a 100 tool list in my cam software and other machines and I would like to use the same list. The control lists 99 places for offsets, but I can't figure out how to number my tools over 20 in the tool changer. Thanks
    Jul 2009
    317
    There is no way to renumber the tools 1-21.
    Jun 2004
    236
    Not exactly sure what your question is, But one of the benefits I have found
    with these machines is ability to set any tool pocket as tool 1 using
    command "Setto"
    Wayne
    Visit our face book page, search on FaceBook; High-Desert-Precision-CNC-Machining-Nosalas-Hobby-Shop
    Aug 2009
    15
    My question was can you use a tool number other then 1-21. The answer apparently is no. On most machines you can assign a tool number to a pocket. In my situation, when using multiple machines, you can work from a universal tool list and swap tools between machines easily.
    Jan 2005
    53
    You can call upto 99 diffrent tool offsets, but as denmar stated, the tool numbers are assigned as 1 thru 21.
  1. macro for serial numbering?
    By Mark Pelnar in forum Okuma
    Last Post: 05-07-2011, 10:41 AM
  2. Tool Numbering, What's Your Method?
    By David Bord in forum Tormach Personal CNC Mill
    Last Post: 03-08-2011, 11:20 PM
  3. quick numbering of parts
    By jarend in forum EdgeCam
    Last Post: 07-30-2010, 12:18 AM
  4. Line numbering for mach3?
    By fatal-exception in forum ArtCam Pro
    Last Post: 07-11-2008, 04:18 PM
  5. line numbering
    By xairflyer in forum G-Code Programing
    Last Post: 05-10-2005, 08:22 PM
