603,335 active members*
3,321 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > NVEM v5 SSR Reley problems
Results 1 to 4 of 4
    Feb 2024
    5
    Hello, I have a problem with NVEM V5 and SSR relay.
    It is connected as in the attached picture.
    Settings in the MACH program in the attached pictures.
    MPG that I made myself is connected as in the attached picture
    When I give the command M7 or M8 the relay does not turn on
    MPG when I activate the axes switches to the X,Y and Z switch but the selection x1, x10 and x100 does not work and when I turn the encoder nothing happens.
    The encoder is 100pps, -, +5v, A and B, so with 4 pins
    Can someone help me where I am wrong and how to solve the problem.
    Thanks in advance
    Attached Thumbnails Attached Thumbnails ScreenHunter 477.jpg   ScreenHunter 478.jpg   ScreenHunter 391.jpg   viber_image_2025-04-18_15-40-43-920.jpg
    Apr 2018
    166
    Re: NVEM v5 SSR Reley problems
    The images that are missing on the CNCZone post are viewable here: https://en.industryarena.com/forum/s...71#post2613071
    Feb 2024
    5
    I power the NVEM v5 with 24v. The motors for all axes are connected, the proximity sensors are connected and everything works fine. But I can't get the two relays for the water pump and the dust collector to work.
    Apr 2025
    Wich output do you use for the waterpump and dust collector?
    I use output 1 to trigger a relay which activates my plasma torch. I had to run a wire from the negativ 24 V to the COM of „Spindle“. And then a wire from Out1 to the relay input. Now I can trigger the relay with mach3.
    The relay is also on the 24V DC Power supply.
    Hope this helps you with your problem
