587,787 active members*
2,359 visitors online*
IndustryArena Forum > Community Club House > O/T Mouse Settings.."Snap To"
Results 1 to 14 of 14
    Apr 2003
    1876
    Is there a way of getting straight to the SNAP TO toggle of the mouse/pointer options? I love having it on about 50% of the time, and HATE it the other 55%. When in Mastercam, I want to be able to toggle it on and off without having to open mouse properties, click the right tab, then click the toggle button.
    I'm pretty sure that data is stored in the registry, but don't know where. If it IS there, I can write 2 reg files that will toggle it, then run those files from my quick launch.
    Is this AT ALL possible? Or am I all wet?
    TYIA
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Mar 2003
    4826
    Try searching regedit for
    SnapToDefaultButton
    HKEY_LOCAL_MACHINE| SOFTWARE| MICROSOFT| WINDOWS NT| INIFILEMAPPING| WIN.INI| WINDOWS
    There is a bunch of stuff in there to do with mouse.
    First you get good, then you get fast. Then grouchiness sets in.
    Apr 2003
    1876
    I can change it in the Mouse Options dialog and it updates the registry. I can't change the registry and have it update. Mayhaps there's another setting that goes with it?
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2003
    109
    It is the correct registry key, but you need to send a WM_SETTINGSCHANGE for it to take effect.
    I wrote a small commandline utility that will let you change the snap to setting without rebooting.
    http://ullberg.us/files/MouseControl.zip
    usage:
    MouseControl.exe /snaptodefault [true|false]
    if you run it without any command line parameters at all it will toggle the setting.
    disclaimer:
    I wrote this in 5 minutes, it looks like it is working fine for me on windows 2000, but there may be bugs. Some other restrictions are that the command line parameters need to be in lower case and you also need the .NET framework 1.1 installed.
    Let me know if you dont want to install the .net framework and i'll write a c++ version instead.
    hope this helps
    edit: Changed the link to a zipfile
    Jul 2003
    109
    Updated the zipfile with a c++ version of the program.
    This version has even less features.. all it does it toggle the setting and exit. No feedback and no command line parameters. I can add that later if you want. (didnt want to spend a lot of time on it if you already had the .net framework installed)
    Apr 2003
    1876
    Thanks ullbergm. That works.
    Question; I do VB6 programmin, where do you send the WM_SETTINGSCHANGE message? Can I do this with VB6?
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2003
    109
    It's been a while since i did VB.. I may take a look at it later on today, but here is the basic idea:
    You need to call a windows api called SystemParametersInfo
    BOOL SystemParametersInfo(
    UINT uiAction,
    UINT uiParam,
    PVOID pvParam,
    UINT fWinIni
    I dont remember how to import external dll's in vb right now but after you import it you call it with the following parameters:
    Get the value:
    uiAction = SPI_GETSNAPTODEFBUTTON (0x005F)
    uiParam = 0
    pvParam = reference to a integer
    fWinIni = 0
    if pvParam is 1 it's enabled, 0 disabled
    Set the value:
    uiAction = SPI_SETSNAPTODEFBUTTON (0x0060
    uiParam = 1 or 0 (depending on if you want to enable or disable it)
    pvParam = reference to a integer (may be able to set this to null, not sure, dont use it anyways..)
    fWinIni = SPIF_SENDCHANGE (0x0002)
    All i did was to read the previous value and set it to the opposite to toggle it.
    Here is the c# code to give you some idea of what it looks like:
    public static bool SnapToDefault
    get
    int bRetValue = 0;
    (uint)SPIActions.SPI_GETSNAPTODEFBUTTON,
    0,
    ref bRetValue,
    return bRetValue == 1;
    set
    int bRetValue = 0;
    int NewValue = (value ? 1 : 0);
    (uint)SPIActions.SPI_SETSNAPTODEFBUTTON,
    (uint) NewValue,
    ref bRetValue,
    (uint)SPIWinINIFlags.SPIF_SENDCHANGE
    Jul 2003
    109
    one more thing, i didnt include any error checking at all. you should check the return value of SystemParametersInfo it returns a boolean telling you wether the call was successful or not. If it fails you should call GetLastError
    Here is the MSDN page explaining the function:
    http://msdn.microsoft.com/library/de...metersinfo.asp
    Apr 2003
    1876
    I got it to work in VB.
    This is just running it on a form with
    2 command buttons. I'm going to set
    up a tray icon to toggle it.
    Thanks again for your help!
    PHP Code:
    Option Explicit
    'Add 2 command Buttons...
    Private Declare Function SystemParametersInfo Lib "user32" Alias "SystemParametersInfoA" (ByVal uAction As Long, ByVal uParam As Long, ByRef lpvParam As Any, ByVal fuWinIni As Long) As Long
    Private Const SETSNAPTODEFBUTTON = &H60
    Private Const GETSNAPTODEFBUTTON = &H5F
    Private Const SENDWININICHANGE = &H2
    Private Function isSnapToDefault() As Boolean
      Dim ilpvParam&
      Call SystemParametersInfo(GETSNAPTODEFBUTTON, 0, ilpvParam&, 0)
      isSnapToDefault = ilpvParam&
    End Function
    Private Function SetSnapToDefault(ByVal SnapToDefault As Boolean)
       Call SystemParametersInfo(SETSNAPTODEFBUTTON, SnapToDefault, 0, SENDWININICHANGE)
    End Function
    Private Sub Command1_Click()
      MsgBox "Snap is: " & isSnapToDefault
    End Sub
    Private Sub Command2_Click()
       SetSnapToDefault (Not isSnapToDefault)
    End Sub
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2003
    109
    you're welcome
    glad i could help
    Apr 2003
    1876
    Update..
    I made this with ullbergm's help and some help from Extreme Visual Basic Forum. If anyone wants, you're welcome to it.
    What I do (for now, until I set it up to run from the tray), is put a shortcut in my quick launch and toggle it on and off when I need to.
    :edit:
    BTW, this will only work on OS's that support this mouse function, and may only work on XP and 2k machines.
    :/edit:
    'Rekd
    Attached Files Attached Files
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2003
    109
    Re: Update..
    Cool, isnt it satisfying to write something that is actually useful?
    I do software development for a living and it's great when you can see people actually use what you wrote and that it is making their work easier.
    :edit:
    :/edit:
    'Rekd
    This is what microsoft says in the sdk documentation.. Not sure if it actually works in practice or not.. but they say it will work all the way back to Windows 95..
    Requirements
    Client: Included in Windows XP, Windows 2000 Professional, Windows NT Workstation, Windows Me, Windows 98, and Windows 95.
    Apr 2003
    1876
    Hell yes.
    I've done some neet things for the 'machining' industry.
    My very first project, (4-5 years ago in BASIC, since converted to Visual Basic), is called M98 Px. It converts NC files to run multiple parts using sub programs. It was, for a first time programmer, very intense.
    I've also made programs for doing file transfers to and from CNC machines, a speed-feed-sfpm-blah-blah-drill point depth calculator, a very small profile MM to English calculator, a util to convert G83 cycles to use I J and K for deep hole drilling, utils for numbering NC files, and a few others.
    It's great being able to make something you need/want instead of having to find and/or buy it.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2003
    109
    Hell yes.
    'Rekd
    Exactly.
    Maybe that's why the CNC stuff interests me as well..
    Cool stuff
  1. Mutilated mouse DRO (using Microsoft PS2 Mice)
    By wcarrothers in forum CNC Machine Related Electronics
    Last Post: 03-30-2009, 05:37 PM
  2. Fun with steppers (From serial mouse to stepper)
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 07-21-2004, 06:41 PM
