603,348 active members*
2,435 visitors online*
Page 2 of 3 123
Results 21 to 40 of 46
  1. #21
    Jun 2015
    943
    Re: Odd G01 behavior in Mach3?
    No problem man.
    You know with a plasma machine it is not really an option to just lower the acceleration because it burns the sheet on the corners if the acceleration is too low.
  2. #22
    Dec 2004
    95
    Quote Originally Posted by 109jb View Post
    20 in/sec^2 is not what I would call "high acceleration" by any means. Also, since your last post reveals that you are using the demo version of Mach, the manufacturer documentation says the demo is limited to 25kHz. 25 kHz and 20,000 steps/in would only be 75 IPM. are you using external step generation or parallel port?
    For a newbie like me who rolled off a turnip truck last night, 0 to 300IPM in .25 seconds is subjectively high for a mill. But assume I had access to YouTube and Google while on the truck so know what else is out there. Please don't get that ignoramus started on about his 2G machines.
    Been using parallel port at 100KHz kernel frequency for the last 6 years or so without issues even though the demo limitation states;
    •Kernel Frequency locked at 25kHz (only applicable if using the parallel port driver)
    Attachment 359216
    LinuxCNC limits me to around 65KHz based on latency test jitter. It's the main reason why I seldom use it. One would have thought that with its RT extensions it would outperform Mach3 in this area.
  3. #23
    Dec 2004
    95
    Quote Originally Posted by OlfCNC View Post
    No problem man.
    No, I didn't realize that. Good to know.
  4. #24
    Jan 2005
    15362
    Quote Originally Posted by eldata View Post
    6 years and you are still a newbie, must be a very slow learner, seems like you want everything for free and work perfect, it's not going to happen
    Just for your smart ass comment/fail, 2G is common day stuff if you have any knowledge of this business, 4m/sec +/- 2 micron accuracy at that speed, most linear servo motors do this all day long, not just the one's I have and use
    Mach 3 because it is not closing the loop with your setup, has very little to do with the Acceleration /Deceleration, your problem is your Servo Drive, settings or the servo drive it's self, not being able to handle the Deceleration, anyone who uses Mach3 with servos will tell you the same thing, your Servo is doing all the control of the Servo Motor, Mach3 is just throwing code at it
    You have not said what servo's and motors you are using or Encoder count, this all plays the main part of the system
    Mactec54
  5. #25
    Mar 2003
    35494
    No, the problem is with Mach3. It's been documented numerous times over the last 5-7 years.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  6. #26
    Jan 2005
    1943
    @mactec54. Part of what you said is just not true.
    Mach3 is not "just throwing code at it". Mach3 still has to send step and direction signals to the servo drive and it still has to send those step pulses such that the servo will accelerate smoothly and decelerate smoothly at the ends of the motion. if a controller doesn't do this, then the drive will fault, but it isn't a problem with the drive, it is a problem with the step signals that were sent to it.
    So, it still makes no sense that a G1 F300 move will fault the drive whereas a G0 with a max axis speed of 300 will not. This problem is still inside mach3, not in the servo drive.
  7. #27
    Jan 2005
    15362
    Yes correct when running Steppers, you do not have this problem when running quality servo's
    Mactec54
  8. #28
    Mar 2003
    35494
    Yeah, if they infinite acceleration....
    Gerry
  9. #29
    Jan 2005
    15362
    No when you have a closed loop Servo Drive the Drive is in control not Mach3, when you are using steppers that is the case, but not with a servo drive is closing the loop
    That is why anyone using quality AC Servo Drives and Mach3 do not have a problem with this at any speed, some 3D high speed profiling I have had problems, as others have, but never with normal G1 moves
    I guess I have to do another Video and show his same settings, and double them at that to show that there is not a problem with G1 moves
    Mactec54
  10. #30
    Jun 2015
    943
    That's true that with quality servos you will not loose steps, but your machine will still jerk and shake when this abnormal decceleration happens.
  11. #31
    Jan 2005
    15362
    That jerk and shake you see is that you have the acceleration set to high, if you have this set correct it will be as smooth as silk
    Mactec54
  12. #32
    Mar 2003
    35494
    Not when Mach3 sends steps without the correct acceleration rate. You can't immediately jump from one position to another without acceleration, and that's what Mach3 does. You either get a jerk, or a fault. Not smooth as silk motion.
    Gerry
  13. #33
    Dec 2004
    95
    Recapping/clarification (probably useful for those with the attention span of a drunken wombat)......
    There was never any issue with a single G1 move like this;
    G1 Z-9 F300
    There was no faulting or jerking whatsoever during acceleration or deceleration. The issue arose when there were two diametrically opposite G1 moves like this;
    G1 Z-9 F300
    G1 Z0
    The drive faulted during the acceleration phase at the beginning of the G1 Z0 move as though the deceleration phase of the G1 Z-9 F300 move never occurred or didn't complete properly. In other words, the start of the G1 Z0 move was not synchronized with zero velocity. If the same thing happened using G0, instead of G1 commands, then I would have simply concluded that the acceleration setting was too high.
    Furthermore, both the following correct the issue;
    G1 Z-9 F300
    G4 P0 ;dwell/pause
    G1 Z0
    or
    G1 Z-9 F300
    G0 Z-9 ;no physical move or pause
    G1 Z0
    (The second workaround is a better choice since there is no pause)
    This, together with the fact that LinuxCNC had no issues using the same settings, has led me to conclude that something odd is happening during or immediately after the deceleration phase of the G1 command in this reversal scenario. This is the first time coming across a Mach3 G1 issue in over 6 years of use but it's also the first time attempting to use Mach3 as a programmable square wave sweep generator. I have no doubt that others have seen similar issues associated with the G1 command.
  14. #34
    Jan 2005
    15362
    A good servo drive will fault if the steps don't follow what is programed
    The Video I have just done will show different, and I did it using the Parallel Port, on an old XP IBM $100 computer, it is a whole lot better to use UC100 or the Smooth Stepper, with Mach3, but I used the parallel port on purpose, as the worst case scenario, to show that it can run at those speeds without problems if the user knows what needs to be set up, and with a good servo system, anything is possible
    Mach3 means very little once you add a motion controller like the UC100 Etc
    Would I use Mach3 by it's self, most likely not, but if I had nothing else, and limited the speed that you run at, it works well for what it is, it's been a great work horse for thousands of user's all over the world, the Hobby world would not be where it is today, if it was not for Mach3
    Mactec54
  15. #35
    Mar 2003
    35494
    Your ignoring the fact that there are bugs in Mach3.
    I still run my machine with Mach3, as do tens of thousands of others. And 99.5% of these people never see these bugs.
    But there are serious bugs, and you can't ignore them, as much as you keep trying.
    Gerry
  16. #36
    Jan 2005
    15362
    G1 Z-9 F300
    G1 Z-9 F300
    G1 Z0
    G1 Z-9 F300
    G4 P0 ;dwell/pause
    G1 Z0
    or
    G1 Z-9 F300
    G1 Z0
    Just ran what you posted, changed it so Mach3 would accept it and it ran correct, more than 20 times
    G1Z-9.F300. ( G1 is modal you only need to use it once or if there is a change)
    Z0.
    M30 (M30 will rewind it to the start of the program)
    Your 300IPM might be on the edge for your machine, back it of until it runs
    Mactec54
  17. #37
    Jan 2005
    15362
    I have never said that Mach3 does not have Bugs, that will most likely never be fixed/ resolved,
    Mactec54
  18. #38
    Jan 2005
    15362
    So here is the Video running 3 axes simultaneous, Z is not in the Video as it is being redesigned, it starts off at 100 IPM and then at 300 IPM
    https://www.youtube.com/watch?v=cAJaIowXwAY
    Mactec54
  19. #39
    Dec 2004
    95
    Z0.
    You didn't see this post...
    What you said makes sense...If I reduced acceleration (and hence deceleration) from 20in's/sec/sec to 10in's/sec/sec the issue would go away with the same 300IPM feed rate. Feed rate was never the issue, it was deceleration all along. But I chose to keep that to myself until now. The fact that Mach3 G00 moves have no issues with 20in's/sec/sec, LinuxCNC G01 moves have no issues under the same conditions, and placing G00 "placebo" instructions immediately after Mach3 G01 move instructions have no issues, suggests there can be issues with the Mach3 G01 command when relatively high deceleration is involved. I was never going to spend $175.00 just to find out whether Licensed Mode had issues or not, so thank you for your contribution to this thread.
  20. #40
    Dec 2004
    95
    Is the video in slow motion?
Page 2 of 3 123
  1. Unexpected behavior from Mach3
    By kievari in forum Mach Software (ArtSoft software)
    Last Post: 11-21-2013, 03:26 PM
  2. M30 Behavior
    By SCzEngrgGroup in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-10-2013, 04:03 AM
  3. Controller behavior
    By Mr_C in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-28-2012, 06:40 PM
  4. Mach3,home sw. Erratic Behavior
    By rcpilot82 in forum Machines running Mach Software
    Last Post: 01-31-2009, 06:08 PM
