603,316 active members*
2,685 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > OemDRO39 not working, but UserDRO 1004 from plug in works ok.
    Feb 2016
    4
    Question OemDRO39 not working, but UserDRO 1004 from plug in works ok.
    Good day everyone at CNCZone!
    I had to rebuild my PC, and yes now I can not get my OemDRO 39 (True spindle RPM) to work anymore. It used to work, I cannot figure out what I am missing. I am runnign a VFD plug in configured to output spindle speed to UserDRO 1004. That works ok, but somehow I am missing the step to get the OemDRO 39 to work.
    I am sure I am missing something small, but alas, finding that small oversight will be the last place I look! And I am still looking...
    I have included my screen set and configuration file. The screen set is my tweak on the 1024 default screen set.
    Attached Files Attached Files
    Feb 2016
    4
    Re: OemDRO39 not working, but UserDRO 1004 from plug in works ok.
    I had a look again last night, still can not get the plug in to update DRO39 as it had before. I had no special scripts or anything to make it work, maybe it was just a happy accident. I tried enabling modbus control, but to no avail. Did not have any brain functions enabled before either. I just work seamlessly. I was almost out of my trail period, maybe I should get Mach4 instead, IF it supports the plug ins...
    My UserDRO 1004 does work, maybe best to just replace the DRO39 with the working UserDRO 1004 and update my scrips to look at 1004 for RPM. Not sure if this would have any negative effects on Mach3?
  1. UserDRO which one
    By leharker in forum Mach Software (ArtSoft software)
    Last Post: 07-22-2014, 04:57 PM
  2. Tachus42 Driver >> Works in Kcam 4 and NOT working in Mach3
    By king master in forum Mach Software (ArtSoft software)
    Last Post: 12-18-2013, 12:12 AM
  3. Replies: 2
    Last Post: 08-20-2010, 06:41 AM
  4. Works in KCam, Not working in Mach3
    By Cooper in forum Mach Software (ArtSoft software)
    Last Post: 03-11-2007, 05:41 PM
