Replacing the filters will be really finicky, even taking off the way covers is finicky. If you have been using the oil Haas recomends it is not likely anything is blocked. Also based on my experience it is not likely the pump has failed. You can do a test with the manual pump. Pull it up and when you release it the pressure gauge should show pressure (I forget how much). This should drop to zero in more than ten minutes but less than thirty minutes. If it drops quickly there is probably a leak somewhere. If it drops very slowly then something is blocked.
You should also look at the oil level. If it has not dropped then aomething is probably wrong. Also look at the waste oil bottle, if this is empty then way oil is not getting through.
