603,981 active members*
2,887 visitors online*
Results 1 to 13 of 13
    Mar 2004
    576
    Oil seal sources?
    I need just one silly little oil seal to get my mill head back together, but can't find it anywhere in short time -- 35mm x 45mm x 8mm, preferably double-lip. HF wants 6-8 weeks, Grizzly says end of March, McMaster doesn't have this size, and all local sources said they'd have to order it, and may take a couple weeks.
    Any other sources that may have this in stock?
    Cheers,
    -Neil.
    Mar 2009
    21
    Maybe
    Hello, I build and repair hydraulic cylinders for customers often in my machine shop, I have many seals in stock and can have almost anything in a couple days, can overnite for EXTRA,... UPS isnt cheap anymore
    Im in Ohio near toledo,
    My personal cell phone is 419-773-9518
    Adam T. Bryan
    L & B TOOL
    Apr 2007
    2580
    MIght give Bob a call...
    Bob Bertrand at lathemaster keeps some parts for the gear head mills but not sure if he has that one. Worth a try... peace
    Mar 2004
    576
    Adam, do you have this size? .. 35mm ID x 45mm OD x 8mm thick (though I suspect other thicknesses near that would be fine).
    Lathemaster does not have it. Neither does Enco (my mill should be the same as a Rong-Fu RF-31).
    Feb 2010
    have you tried a local bearing supply place? they can usually get anything within 24 hours
    Mar 2004
    576
    Quote Originally Posted by hi_im_sean View Post
    All of them... not kidding. Actually, I found one who was local to me that said they had it, but said I'd have to order it off their website, as they don't allow pick-ups. And then I could not find it on their website.
    Mar 2009
    21
    Seal
    Is this a metal clad seal (press in style)
    Or is it all rubber and snap in?
    Adam
    Mar 2004
    576
    Hmmm... I think it's a press-in style. It's this...
    Mar 2009
    21
    seal
    Well its already junk right? Get it out of there so we can have a good look, I buy seals like this all the time.. Less than $20 but ups will hit you $10 or $12
    Pull it out and send me pics so I can match it.
    Adam
    Mar 2004
    576
    Ugh -- was hoping you wouldn't say that. Looks like I will need to put it back together this Friday, even with a leak, so that I can get some machining done this weekend (robotics-club stuff). I can send it to you next week.
    Mar 2009
    21
    seal
    I can have you one delivered to you buy friday If Your sure what it is?
    Pay overnite fee...
    Im looking in my book right now and have a 35 x 45 x 7 mm
    Its only .039" shorter in height and if it press in it wont matter.
    Adam
    Mar 2009
    21
    seal
    You can call my cell phone tomorrow to place an order if you want, Im only at computer at nite...
    Adam
    L & B TOOL
    419-773-9518
    Mar 2004
    576
    I'll call you tomorrow when I get over to the shop (where the machine is).
    Cheers,
    -Neil.
  1. Seal MDF spoilboard?
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 01-26-2016, 11:01 PM
  2. Compressor seal lubricant
    By skmetal7 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-02-2007, 04:34 AM
  3. seal for spindle
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 04-08-2006, 09:07 PM
  4. R & R Of Sheetmetal What to Seal With!!
    By chipsahoy in forum Fadal
    Last Post: 03-18-2006, 06:14 AM
