587,231 active members*
4,635 visitors online*
Results 1 to 4 of 4
    Nov 2011
    83
    Oiling micrometers/calipers and other tools
    In the shop i work in i continously come in contact with solvent cleaning dies for pm work, coolant while running grinders and mills, oils from tapping etc, so at the end of the day i really give my micrometers, calipers etc a good wipe down to remove any dirt oils etc. I do not oil any of my tools, i have all starrett stuff so i have bajillions of dollars in tools, id like to keep them working for the entirety of my career, what is everybody doing for oiling they're tools? what type of oil? I currently just wipe mine off with a microfiber towel and nothing else.
    May 2004
    4519
    Way lube? I would not use any aerosol oil or lube, especially not WD-40. I never had a problem with tools and corrosion. Usually there is enough way lube and other oil flying around a shop to coat everything. I would be careful when wiping dust off my tools to not wipe all of that oil off of them.
    Sep 2012
    1543
    I blow mine off with the air gun, gets little pieces of metal out of the teeth, and anything hidden up inside. I check them for adjustment and put a drop of Royal Purple Max Film on each contact surface and work back and forth, then towel off and put in the drawer. It's like a new caliper everyday.
    I have the max film in a syringe with a needle, I use it for a lot of things and you waste less of it doing it this way.
    Dec 2005
    600
    Starrett Tool and Instrument Oil
  1. Micrometers The right one for the Job Huge Selection
    By CDTooling in forum News Announcements
    Last Post: 12-20-2010, 03:48 PM
  2. Why digital calipers are better than the old dial (rack & pinion) calipers.
    By widgitmaster in forum Calibration / Measurement
    Last Post: 12-14-2008, 02:12 PM
  3. Holtests, Hole micrometers???
    By groovemixer in forum MetalWork Discussion
    Last Post: 03-12-2007, 05:04 AM
  4. who makes best coolant proof micrometers??
    By blazer928 in forum Uncategorised MetalWorking Machines
    Last Post: 03-10-2007, 07:58 AM
  5. digital calipers
    By skmetal7 in forum CNC Machine Related Electronics
    Last Post: 01-09-2007, 03:13 AM
