603,348 active members*
3,906 visitors online*
IndustryArena Forum: Okuma
Page 102 of 179 25292100101102103104112152
Threads 2021 to 2040 of 3575
Discuss Okuma machines here.
  1. Okuma Multus B300 Turret X center alignment
    Started by vkrau, 07-18-2014 06:01 AM
    adjust, alarm, axis, bar, center, clamp, dial, experience, fixed, headstock, machine, main spindle, method, okuma, position, runout, spindle, switch, tolerance, turning, turret
    07-25-2014, 03:21 AM Go to last post
  2. Post okuma mx 40 ha. seeking g+m code meanings
    Started by aheronomore, 07-24-2014 01:45 AM
    11m, 300, 3000c, code, different, fanuc, favorite, instruments, list, loadable, lordy, m code, mazaks, mine, moved, okuma, okumas, person, square, sys, systems, texas, wow
    07-24-2014, 01:45 AM Go to last post
  3. OSP5000M-G MC-4VB
    Started by KHOATRANNGOC, 07-19-2014 04:33 PM
    alarm, cnc, cnc machine, disk, double, email, floppy, floppy disk, help me, install, machine, mc-4vb, okuma, okuma osp, osp, osp5000m-g, ran, software, stall, tra, ware, yahoo, yahoo.com
    07-23-2014, 02:36 AM Go to last post
  4. Button and cursor freeze
    Started by gunda, 06-21-2014 07:28 PM
    anything, art, buttons, check, cnc, cursor, freeze, hardware, machine, move, multus, offset, panel, realized, restart, run, running, swi, switch, tons, trouble, wanted, works
    07-20-2014, 11:47 PM Go to last post
  5. Booting OSP200L from USB CDRom - Factory XP Disc
    Started by techrat, 07-15-2014 03:34 AM
    ..., bios, boot, data, dies, disk, drive, error, error message, failure, files, hard, hard drive, insert, machines, message, problem, shop, system, tools, usb, windows, windows xp
    07-17-2014, 07:27 PM Go to last post
    07-17-2014, 07:21 PM Go to last post
  6. Angry Okuma-Howa HL-20
    Started by howd, 01-24-2008 04:42 AM
    07-16-2014, 02:55 PM Go to last post
  7. Fanuc 6T Servo 400 Alarm
    Started by cic108, 06-11-2014 05:58 AM
    alarm, center, control, fanuc, fanuc 6t, hour, hours, machine, ops, seiki, servo, stops, turning, turning center, working
    07-07-2014, 02:08 PM Go to last post
  8. dnc output of tool geometry offsets
    Started by seven3, 07-04-2014 08:54 PM
    advise, changing, con, control, data, dnc, geometry, input, mac, machine, macturn, measure, offset, offsets, osp, osp700, output, pack, put, time, tool, tools
    07-05-2014, 08:00 AM Go to last post
  9. DNC-B and Rs232 on U10M controller
    Started by 17asleep, 06-18-2014 05:31 PM
    cincinnati, communication, controller, dnc, dnc-b, error, file, fire, floppy, ice, limit, machine, memory, okuma, parameters, problem, rs232, set up, size, threads, translate, usb, work
    06-24-2014, 03:28 PM Go to last post
  10. check center sensor before facing
    Started by duivenhok, 06-20-2014 07:47 PM
    center, check, end, facing, forward, made, mistake, position, program, rotation, safe, safety, sensor, spindel, spindle, star, starting, today, variable, words, workpiece
    06-20-2014, 07:47 PM Go to last post
  11. Exclamation Memory board/battery alarm 4035
    Started by lmbma, 09-26-2012 07:30 AM
    4035, alarm, battery, machine, replaced
    06-17-2014, 03:39 PM Go to last post
  12. Battery change OSP7000L
    Started by bengt65, 06-21-2010 11:12 AM
    alarm, battery change, diskette, okuma, osp7000l
    06-17-2014, 03:31 PM Go to last post
  13. Rigid tapping Macturn 350 OSP 200
    Started by Green Button, 03-07-2014 09:12 AM
    ..., axis, b-axis, basic, code, deep, forming, holder, hours, job, mac, macturn, make, osp, power, problems, ready, rigid, rigid tapping, rotate, spindle, sta, sub-spindle, subspindle, tap, tapping
    06-17-2014, 01:22 PM Go to last post
  14. LB-15 OSP5020, Tool Offsets not working correctly
    Started by InventIt, 06-09-2014 02:33 AM
    comp, control, lathe, part, tool
    06-11-2014, 04:32 AM Go to last post
  15. Need help okuma osp5020 ATC problem
    Started by cic108, 06-10-2014 11:08 AM
    06-10-2014, 03:46 PM Go to last post
  16. Question U100L number of offsets
    Started by fomaz, 06-03-2014 06:45 AM
    control, easy, number, offset, offsets, tools
    06-08-2014, 11:22 AM Go to last post
  17. Lightbulb Okuma MCva3 1987 Mill
    Started by Vince Loy, 06-07-2014 12:23 AM
    500m-o, controller, helical, machine, mill, okuma, osp, serial, threading, vertical, vertical mill
    06-07-2014, 11:13 PM Go to last post
  18. Okuma Howa Act20 turret index
    Started by acidav, 06-06-2014 11:35 AM
    18t, act20, control, fanuc, fanuc 18, fanuc 18t, home, howa, index, okuma, tool, turret
    06-07-2014, 11:03 PM Go to last post
  19. (Live) VDI tool holders
    Started by iMillJoe, 06-21-2013 08:06 PM
    06-07-2014, 12:59 AM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 16 users browsing this forum. (0 members & 16 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
