587,999 active members*
5,441 visitors online*
    Okuma axis disable
    Hello, does anyone have an idea how to disable an axis on a Okuma LR15-2m Machine? I have live tooling that i am not using, and the BL-D drivers are often failing , so i would gladly disable them to use the machine at least without live tooling.
    Aug 2018
    4
    Re: Okuma axis disable
    Its possible to find this topic here on forum, made this before and it works . Just search here or in google ( link should come to the same topic).
    Mar 2009
    1982
    The question is if BL-D alarm goes away with axis disabled.
  1. 4th axis disable/enable
    By davesnd in forum Fanuc
    Last Post: 07-04-2023, 08:38 AM
  2. OKUMA LR-15 OSP5020L axis disable
    By kotronik in forum Okuma
    Last Post: 04-15-2020, 04:13 PM
  3. Disable 4th and 5th Axis
    By IrishJ in forum Kitamura
    Last Post: 06-29-2019, 03:15 AM
  4. Disable 4th and 5th axis
    By kudos in forum CNC Machining Centers
    Last Post: 05-08-2015, 09:11 PM
  5. Fanuc 16i-M 4th axis disable
    By MDR32 in forum Fanuc
    Last Post: 07-23-2010, 01:07 PM
