Originally Posted by
bryanbdp
Hi. My Z axis motor got hit hard enough to fracture the motor end cover. Although the encoder looks OK, I am getting an error "065 ALARM P" "SVP start 1021A08"
It also says Memory Test OK, Load SYS
then: EC PROCESSOR ON INITIAL PROCESS
SERVO PROCESSOR ON INITIAL PROCESS
SBP MONITOR
>_
Can anyone tell me if this is likely due to the encoder or some other cause?
I was looking at used encoders and it seems almost the same price to buy the whole motor including encoder, plus it hasn't been pulled apart.
The part number on my motor is BL-MH101E-12SB
Can anyone tell me if there is a difference (that matters) with a BL-MH101E-12S ?
Both are 1200rpm, 6 pole, 155v, 5A, 1.2KW and have same encoder, ABS-FB-D2048
Also, are any other the newer encoders directly interchangeable?
Thank you,
Bryan
