603,385 active members*
3,235 visitors online*
    Hello Okuma CNC-Miller,
    if you've problems with programs or macros - then let me know.
    Maybe I could help you....
    The first one i made worked fine using r-comp both in, round and out, but i can max use a 10mm cutter to make a 20mm hole.
    and that sux when i allready have a 12 and 16 in the chain.
    There for Im making a new macro and where i need to read out the value of cutter no. 5
    but something is wrong !! :???:
    I dont know if my cutter value read is correct ?
    Also its like Y dont go 100 when G41 (maby because of zero movement!!)
    It also looks like the 360 hole moves in Y !!
    anyone ????
    (CALL MACRO)
    G113 HR=100 HQ=20 HZ=-4 F1220 D5
    OICIR (G113)
    (PRE-POS. IN CENTER OF HOLE)
    (MACRO DESC.)
    (CIRCLE IN)
    (360 HOLE IN CUTTER COMP. WITH OR WITHOUT INT.POL.HELICAL)
    (CLEAN UP OR NOT)
    (CIRCLE OUT)
    (HR=HOLE RADIUS)
    (HQ=NO. OF REPEATS)
    (MUST BE 1 OR BIGGER)
    (HZ=INCREMENTEL Z FOR HELICAL)
    (MUST BE 0 OR LESS)
    VC1=VDCOD (ACTIVE CUTTER OFFSET NO - D-NUMBER)
    VC2=VTOFD[VC1] (VALUE OF D OF ACTIVE CUTTER OFFSET NO.)
    VC3=HR-VC2 (HOLE RADIUS - D-VALUE)
    G40 G91 G3 X0 Y=VC3 J=VC3/2 (CIRCLE IN)
    G91 G1 G41 X0 Y0 (ACTIVATE CUTTER COMP.)
    COPY Q=HQ (REPEAT)
    G91 G3 X0 Y0 J=-HR Z=HZ (360 HOLE INT.POL.HELICAL)
    COPYE (REPEAT END)
    IF [HZ EQ 0] N10 (IF NOT HELICAL DONT CLEAN UP)
    G91 G3 X0 Y0 J=-HR (BOTTOM CELAN UP)
    N10 G40 (KILL CUTTER COMP.)
    G91 G3 X0 Y=-VC3 J=-VC3/2 (CIRCLE OUT)
    G90 (ABSOLUTE)
    RTS (RETURN TO MAIN PROGRAM)
    SAMPLE WITH VALUES
    VC1=5 (ACTIVE CUTTER OFFSET NO - D-NUMBER)
    VC2=20 (VALUE OF D OF ACTIVE CUTTER OFFSET NO.)
    VC3=100-20 (HOLE RADIUS - D-VALUE)
    G40 G91 G3 X0 Y80 J40 (CIRCLE IN)
    COPY Q20 (REPEAT)
    G91 G3 X0 Y0 J-100 Z-4 (360 HOLE INT.POL.HELICAL)
    COPYE (REPEAT END)
    G91 G3 X0 Y0 J-100 (BOTTOM CELAN UP)
    G91 G3 X0 Y-80 J-40 (CIRCLE OUT)
    G90 (ABSOLUTE)
    <span style='font-size:8pt;line-height:100%'>Best/MfG/Hilsen<br><br><b>L</b>eon, <b>D</b>enmark</span>
