603,369 active members*
3,537 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA COMMUNICATION ERROR
Results 1 to 6 of 6
    Feb 2009
    Smile OKUMA COMMUNICATION ERROR
    i am trying to establish a RS232 connection between a pc and okuma LB300 with control U100L. Always i get an error 5235 device name error 2, which i can't solve it.
    Any ideas?
    Dec 2008
    3211
    Please correct me if wrong, but
    does this machine come with a network card and set-up thru the "Macman" application and use an ethernet cable ?
    If yes, it would be better than using a RS232 with a PC terminal, all comms can be done at the machine with no contact with the PC
    does pushing the "!" button near F1 key give any other info on that alarm #5235 ?
    Feb 2009
    My machine hasn't a network card to connect. Sorry!
    i tried to write after "PIP"-"READ"- R CN0:a.min but i get the same error.
    Feb 2008
    3
    I don't know wish DNC program you use but, on our machines, we have:
    $program name.MIN% (at the beginning)
    M02
    % (at the end)
    DNC SETTING:
    BAUD RATE: 4800
    PARITY: EVEN
    DATA BITS: 7
    STOP BITS: 2
    TRY THIS AND GIVE NEWS !!!
    Mar 2009
    1992
    this error indicates wrong device name clearly. The best for beginning is to use default device, set by parameters, not typing device name into command. Pay attention - parameters describes separate serial communication ports for parameters, for reading and for punching part program. By the way, You can use "punch", it would be normal for this control.
    Jan 2010
    Hi have the same problem, but I the punch work, but the read don't work ! I need help to.
  1. Okuma Communication Help
    By smooooooth in forum Uncategorised MetalWorking Machines
    Last Post: 06-21-2011, 03:14 PM
  2. OKUMA LC40 OSP5000L Communication problem
    By Max Moreno in forum DNC Problems and Solutions
    Last Post: 08-22-2010, 07:30 AM
  3. Communication Error
    By the_new_girl in forum PlasmaCam
    Last Post: 11-24-2008, 12:43 PM
  4. Okuma OSP100E RS232 Communication Problem
    By Edster in forum DNC Problems and Solutions
    Last Post: 03-21-2007, 12:57 AM
  5. Okuma communication problem
    By stude8 in forum DNC Problems and Solutions
    Last Post: 02-08-2007, 07:44 AM
