603,388 active members*
2,782 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma-Howa tool change problems.
Results 1 to 5 of 5
    My Okuma-Howa M-4H is in a bit of a jam. I traced a hydraulic leak to the tool change arm, while diagnosing the problem I closed the gripper fingers using the manual controls. The problem is I cannot get them to open up again, nor can I rotate the arm. I restarted the machine to try to clear the problem, now my spindle is no longer oriented to the right place for the tool change and I cannot get it to move (I assume it will not rotate because the tool change arm is out of position). I am also getting alarm 93, but I don't have any manuals so I don't know what that is referring to.
    Is there a command I can give in MDI to orient the spindle?
    What does alarm 93 mean?
    Do you know where I can get some manuals?
    Any and all help is appreciated.
    GJC
    Mar 2003
    2932
    On most CNC mills M19 orients the spindle. What control does it have?
    It has a Fanuc 11M control.
    Thanks for your help.
    Nov 2008
    15
    Which side is this on.... Okuma-Howa or Fanuc?
    I have got past the problem, it turns out that I had to press the 'Machine Ready" button and 'Spindle Orient' at the same time.
    I still need manuals though if anyone knows where I can get one.
    G.
  1. Setting up tool changer on a Okuma Howa
    By 69owb in forum Okuma
    Last Post: 02-14-2015, 05:37 PM
  2. Okuma howa tool geometry protect
    By chrisclegg in forum Okuma
    Last Post: 10-10-2008, 02:36 PM
  3. Difference between a Okuma & Okuma Howa
    Last Post: 06-04-2008, 05:51 PM
  4. OKUMA MC-V4020 tool change jam
    By qbinhtran in forum DeskCNC Controller Board
    Last Post: 02-21-2008, 11:10 PM
  5. Partner I Tool Change Problems
    By Outlaw6700 in forum Milltronics
    Last Post: 02-26-2007, 05:33 AM
