587,189 active members*
3,307 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Lathe "Turret Unclamp Over Time" Error Alarm
    Apr 2016
    3
    Hi. We have an Okuma P200L lathe, and the top turret is throwing this "TURRET UNCLAMP OVER TIME" alarm. The maintenance guy said it isn't the switch. Does anybody know what the problem could be?
    Dec 2008
    3122
    Re: Okuma Lathe "Turret Unclamp Over Time" Error Alarm
    Jul 2016
    3
    Check it's I/O monitor if iTUC and iTUCL are turning on hen you engage turret index if none then check the photosensor or limit switch inside the turret if the dog plate is moving if it is moving when you index probably your limit switch is th problem.
    But if there are no movements try to see hydraulic then check the solenoid look for it on OPERATION AND MAINTENANCe MANUAL
  1. Replies: 5
    Last Post: 09-22-2014, 04:05 AM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. Replies: 8
    Last Post: 02-23-2013, 05:12 AM
  4. Hitachi HT 20 CNC Lathe "turret index time over alarm" after battery change
    By surfit in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2011, 04:35 PM
  5. Fanuc 18t Turret alarm "1110"
    By senna95 in forum Fanuc
    Last Post: 10-18-2006, 05:03 PM
