586,033 active members*
3,481 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > OKUMA LB 15 bus error 89
Results 1 to 4 of 4
    Jun 2021
    6
    Hi everybody i kindly ask your support for the error that can be seen in the attached pictures .
    Mar 2009
    1982
    Re: OKUMA LB 15 bus error 89
    1. Okuma is discussed in the Okuma chapter of this forum.
    2. Tell the story. If the machine was running with this software before?
    It can be the software fault - means, installed software does not belong to this machine.
    Jun 2021
    6
    The machine was working. Then it has been moved and stored for long time. My technician has tried to load sw from original tapes but i gor the reported error
    Jun 2021
    6
    This thread has been moved in okuma section
  1. OKUMA system bus error (SBER)
    By jackywu in forum Okuma
    Last Post: 03-22-2024, 07:09 AM
  2. Replies: 2
    Last Post: 01-14-2023, 06:02 PM
  3. Replies: 10
    Last Post: 08-23-2022, 05:37 PM
  4. OKUMA SVP board: 1-1 CPU Alarm bus error
    By robodo in forum Okuma
    Last Post: 11-13-2017, 10:32 AM
  5. OKUMA OSP700M /MX45VBE bus error
    By terkaa in forum Okuma
    Last Post: 09-04-2015, 11:53 AM
