We purchased 2 used lathes one with OSP-P200L control the other OSP-P200LA. I'm not totally fluent in the programming of these machines yet. The problem is I moved a spot, drill and tap from the main G140 to the sub G141 to balance the cycle time. Usually one time through the cycle it is well timed. But the second time through the timing starts getting all out of whack. The turrets are going up to index to the next tool. There's no P code but the turret sits and waits. It's usually the upper turret and it does it on both machines. It's reeking havoc on my cycle time.
I put P-1 at the top of the programs to reset the P codes. I'm not sure which to use when, P code or M100.
Does anyone have any suggestions?
