587,092 active members*
2,716 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma MB56 graphic problem
Results 1 to 11 of 11
    Jul 2011
    We are machining multiple parts in one program, using g15 H# Is it possible to have a blank for each work offset in the graphic area?
    Dec 2008
    3122
    Yes
    Each seperate stock for each offset should start DEF WORK (offset#) [ syntax should be close - been away from Okumas for a while ]
    & your stocks should be defined before a single END & then a DRAW statement
    You then can define the tools, before having the NC program code.
    Okuma can have a seperate file that is loaded with the .MIN file that has the stock ( I forget the actual extension required ) ( but the filenames must be identical ) , but it is best ( IMO ) to have only 1 file.
    Jul 2011
    Thanks Superman
    We have done this, but only one of the stock shows on the graphics. Please look at our stock definition. Did we do something wrong?
    DEF WORK[1]
    DIREC V
    ORIGIN H4
    CYLNDR 2P,[-77,-52],[77,52],-18,2
    END
    DEF WORK[2]
    DIREC V
    ORIGIN H3
    END
    DRAW
    Aug 2011
    2517
    The second definition is being ignored? You have two END statements and Superman said only a single END statement is required.
    Jul 2010
    287
    I had better luck formatting things like this as so:
    DEF WORK[1]
    DIREC V
    ORIGIN H4
    END
    CLEAR
    DRAW
    DEF WORK[2]
    DIREC V
    ORIGIN H3
    END
    DRAW
    I don't remember why, but that's what I remember working for me.
    Jul 2011
    Thank you tea hole
    I have done what you have suggested inserting the "clear" but is still ignores the second graphic.
    Dec 2008
    3122
    I'm more inclined to go along this avenue
    Code:
    DEF WORK[1]
    DIREC V
    ORIGIN H4
    ORIGIN H3
    END
    CLEAR
    DRAW
    Mind you, it has been a long time since running an Okuma
    Apr 2009
    1262
    This is what works for us on our MC-V4020:
    CLEAR
    DEF WORK[1]
    ORIGIN H1
    CYLNDR 0P,[0,0],24,-17,1
    CYLNDR 0H,[0,0],08,-17,1
    ORIGIN H2
    ORIGIN H3
    ORIGIN H4
    ORIGIN H5
    ORIGIN H6
    ORIGIN H7
    ORIGIN H8
    END
    DRAW
    8 fixture offsets each with it's own cylinder with a hole in the middle.
    Best regards,
    Aug 2009
    37
    Re: Okuma MB56 graphic problem
    Okuma Wiz,
    Can you explain what the information on each line means? I am a newbie to Okuma and I am trying to understand these lines.
    I understand it is a cylinder, but what do the brackets represent? and more so the numbers after?
    CYLNDR 0P<----What does the 0P stand for?
    ,[0,0]<-----[0,0] Is this x,y locations?
    ,24,-17,1<----What are each of these numbers referring to?
    CYLNDR 0H,[0,0],08,-17,1<-------What does the 0H stand for? the Hole?
    Thanks,
    Todd
    Apr 2009
    1262
    Consider 0P = Part, 0H = hole
    [0,0] start drawing at x0 y0
    24 = make cylinder dia = 2.4"
    -17 = make length -1.7" so zero is at top and cylinder is -.1.7 long from z zero
    1 = solid pattern
    Soooo, it draws a cylinder 2.4" diameter with a .8" hole thru it. 1.7" long with z zero at the top of the part.
    Best regards,
    Experience is what you get just after you needed it.
    Aug 2009
    37
    Quote Originally Posted by OkumaWiz View Post
    1 = solid pattern
    Best regards,
    Great! Thank you!
  1. Probing half a circle in MB56
    By iMillJoe in forum Okuma
    Last Post: 04-04-2014, 10:09 PM
  2. X6 graphic problem
    By matesjiri in forum Mastercam
    Last Post: 03-01-2012, 04:30 PM
  3. Replies: 9
    Last Post: 09-09-2011, 11:57 AM
  4. ona prima graphic problem
    By rftools in forum EDM Discussion General Topics
    Last Post: 03-24-2010, 05:45 PM
  5. Mechanic and graphic problem...
    By Cimatron Fan in forum Uncategorised CAM Discussion
    Last Post: 02-19-2009, 05:04 AM
