588,385 active members*
5,481 visitors online*
IndustryArena Forum > CAM Software > Mastercam > OKUMA Mill Poste Edit for " NCYL " subprogram call
Results 1 to 8 of 8
    Dec 2008
    4
    Hello.
    Does anybody run a "NCYL" in OKUMA drill cycle?
    is there a way to POST this with any drill cycle using Subprogams only?
    G17 G40 G80 G90 G94
    G15 H15
    G00 Z20
    IF [VATOL EQ 2 ] N2
    T2
    M06
    M01
    N2 (.250 DIA )
    G00 X-3.0 Y0.0 M3 S1000
    G56 H2 Z3.0
    M08 T3
    G95
    G71 Z2.0
    G00 Z.11
    NCYL G81 Z-.2 R.11 F.0033 M53 ( Sub )
    CALL OS1
    G80 G00 Z2.0
    G94
    M09
    Z20
    M01
    M06
    Y20 Z20 X-12
    M30
    OS1
    X-1.5
    X0.0
    X1.5
    X3.0
    RTS
    G17 G40 G80 G90 G94
    G15 H15
    G00 Z20
    IF [VATOL EQ 2 ] N2
    T2
    M06
    M01
    N2 (.250 DIA )
    G56 H2 Z3.0
    M08 T2
    G95
    G71 Z2.0
    G00 Z.11
    G81 Z-.2 R.11 F.0033 M53 (No Sub )
    X-1.5
    X0.0
    X1.5
    X3.0
    G80 G00 Z2.0
    G94
    M09
    Z20
    M01
    M06
    Y20 Z20 X-12
    M30
    Mastercam Mill Post : Mpmaster for Mastercam X3
    pdrill$ # G81 Canned Drill Cycle
    pdrlcommonb
    pcan1, pbld,?????(NCYL), n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, pindexdrl,
    prdrlout, *dwell$, *feed, strcantext, e$
    pcom_movea
    Thank you for any suggestions.
    Try this.
    "NCYL"
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Dec 2008
    4
    if i force "NCYL" it will post it always.
    i need it oly when im using Subprogam.
    You can set it up as a misc int. to put it in when you want to use it.
    I will do this for you if you send me your post,
    I will send you an email as to how long and what the cost may be include what version you are running too.
    [email protected]
    www.cad2cam.net
    www.cad2cam.net
    Dec 2008
    4
    i was hoping to do it without any extra mouse clicks.. thinking if it read call for sub or anything whatever forcing post sub it will do it automatically .may be something like that or what is the parameter to call sub
    pcan1, pbld,[if ********** = * ,"NCYL",ELSE,], n$, *sgdrlref,.....
    Oct 2008
    45
    yes there is and if i am right it would be in the "peck drill custom parameters" I think that you can set it up in your post it is close to the bottom. I am just not 100% sure but If i am right you would still force it, but could click it on and off. (Think second idea is better>>> )Or you could create a custom cycle for it I think it would work just never tried it.
    May 2008
    I have a OKUMA machine but I havent got any document,can you give me some document about operation and programing.thank
    Dec 2008
    4
    What control?
  1. Okuma "D-Disk"
    By 67highboy in forum Okuma
    Last Post: 01-08-2021, 11:25 AM
  2. "Warco GH Univ" V "Chester Lux Mill"
    By JQ_Quint in forum Benchtop Machines
    Last Post: 01-22-2009, 05:59 PM
  3. OKUMA LB15 "ALARM 206 A Shear Pin 4"
    By RISNA in forum Okuma
    Last Post: 06-16-2008, 04:35 AM
  4. Replies: 2
    Last Post: 06-13-2008, 11:18 AM
  5. "Edit" IGES Files in MasterCam
    By windrider in forum Mastercam
    Last Post: 10-29-2007, 02:32 PM
