603,326 active members*
2,875 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma OSP-P200L parts counter
Results 1 to 8 of 8
    Nov 2008
    Hi everybody!
    I am new in writing posts. But been here for some time, just reading. A lot of useful info. Thanks a lot for that. I just started to work on okuma machine – it is a bit different from fanuc. Love it so far! I have a couple questions. May be someone can help me
    Okuma OSP-P200L, using admac, can work with IGF
    1. Is there a way to set up a parts counter?
    2. How to set several Z offsets on Okuma ( like G54, G55 on fanuc)?
    So far I have not figured it out yet. But working hard.
    Jun 2008
    372
    The easiest way to set the datums is to use the variables
    Set your Datums, This is for a 2 turret 2 spindle machine
    G13
    G140 (MAIN SPINDLE)
    VZOFZ=53631.850
    VZOFW=19704.343
    G141 (SUB SPINDLE)
    VZOFZ=54305.898
    G140
    G14
    (SET B TURRET ZERO)
    G140 (MAIN SPINDLE)
    VZOFZ=53404.459
    G141 (SUB SPINDLE)
    VZOFZ=54324.488
    G140
    Parts counter, There are 3
    (V40=VWKCC[1]
    VWKCC[1]=V40-1
    V40=VWKCC[2]
    VWKCC[2]=V40-1
    V40=VWKCC[3]
    VWKCC[4]=V40-1
    V40=VWKCC[4]
    VWKCC[4]=V40-1)
    Apr 2009
    1273
    You can also use VZSHZ to shift the zero temporarily. But remember that when you hit reset it goes away. I prefer BudgieW's method most of the time.
    You can also use your common variables as counters: (you have more of them if needed)
    V1=V1+1
    IF[V1 GE 20]NEND
    NEND M02
    Best regards,
    Jun 2008
    372
    M02 should tick over the parts counter
    Nov 2008
    Thanks a lot. I entered the code in. What screen do I need to bring on to see the actual count? Looked everywhere today. I am missing something.
    Apr 2006
    825
    Select the Parameter screen and then look for the page that lists your Common Variables.
    In the example given by OkumaWiz the first variable V1 is being used as the counter.
    Sep 2007
    122
    Re: Okuma OSP-P200L parts counter
    All this was a good find . The OSP-300 book shows Work Counter VWRKC[α, β]
    I have never been able to get this to work. VWKCC[α] works fine with α being 1,2,3 or 4.
    1: Work counter A
    3: Work counter C
    2: Work counter B
    4: Work counter D
    α =
    β = 1: Count value 2: Set value
    Dec 2008
    12
    Does anyone have admac for pc? I'm trying to hone my programming skills and I think admac would be able to help me.
    Thank You
  1. Okuma ops p200l how to ues usb port.
    By Twin-10s in forum Okuma
    Last Post: 08-12-2014, 03:03 AM
  2. Okuma OSP-P200L Programing
    By trampus in forum Okuma
    Last Post: 11-19-2010, 04:35 PM
  3. Angle head Okuma VTM-120Yb OSP-P200L
    By ProToZyKo in forum Okuma
    Last Post: 06-27-2010, 08:13 PM
  4. Parts Counter
    By HelicopterJohn in forum Haas Mills
    Last Post: 04-20-2008, 05:05 PM
  5. Okuma parts counter
    By Musclebound in forum Okuma
    Last Post: 02-27-2007, 03:53 AM
