603,914 active members*
2,957 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma OSP U10L 2286-13 Alarm B Plus variable limit over Z-Axis 2
Results 1 to 5 of 5
    Hi Guys,
    I'm new to turning, and finding my way around our Okuma lathe with U10L control.
    I have worked out most of the kinks in the post between fusion and OSP, but this one has me stumped.
    "2286-13 Alarm B Plus variable limit over Z-Axis 2"
    When i look this alarm up, i can see up to 8 possible causes, but this specifies number 13?
    It is happening in the code below, on line N171
    This is the retraction line before a tool change from threading to cut-off.
    Anyone able to help me out here?
    I checked my tool Z- zero offset and its fine.
    (O1023.MIN)
    N10 G50 S3000
    N11 G0 X200. Z200.
    (FACE1)
    N13 T000505
    N14 M8
    N15 G95
    N16 G97 S809 M3 M41
    N17 G0 X78.678 Z4.869
    N18 G50 S3000
    N19 G96 S200 M3 M41
    N20 G0 Z0.283
    N21 X58.678
    N22 G1 X51.506 F0.2
    N23 X48.678 Z-1.131
    N24 X-2.922
    N25 X-0.094 Z0.283
    N26 G0 X78.678
    N27 Z4.869
    N28 G97 S809 M3 M41
    (PROFILE ROUGHING2)
    N29 G95
    N30 G97 S927 M3 M41
    N31 G0 X68.678 Z4.869
    N32 G50 S3000
    N33 G96 S200 M3 M41
    N34 G0 Z-0.531
    N35 X46.278
    N36 G1 Z-45.024 F0.2
    N38 G1 X50.678 Z-46.053
    N39 G0 Z-0.531
    N40 X43.878
    N41 G1 Z-44.291 F0.2
    N42 G3 X46.278 Z-45.024 I-1.4 K-3.64
    N43 G1 X48.278 Z-44.024
    N44 G0 Z-0.531
    N45 X41.478
    N46 G1 Z-44.036 F0.2
    N47 G3 X43.878 Z-44.291 I-0.2 K-3.895
    N48 G1 X45.878 Z-43.291
    N49 G0 Z-0.531
    N50 X39.078
    N51 G1 Z-44.031 F0.2
    N52 X41.078
    N53 X41.478 Z-44.036
    N54 X43.478 Z-43.036
    N55 G0 Z-0.531
    N56 X36.678
    N57 G1 Z-44.031 F0.2
    N58 X39.078
    N59 X41.078 Z-43.031
    N60 G0 Z-0.531
    N61 X34.278
    N62 G1 Z-44.031 F0.2
    N63 X36.678
    N64 X38.678 Z-43.031
    N65 G0 Z-0.531
    N66 X31.878
    N67 G1 Z-44.031 F0.2
    N68 X34.278
    N69 X36.278 Z-43.031
    N70 G0 Z-0.531
    N71 X29.478
    N72 G1 Z-44.031 F0.2
    N73 X31.878
    N74 X33.878 Z-43.031
    N75 G0 Z-0.531
    N76 X27.078
    N77 G1 Z-25.358 F0.2
    N78 X28.878 Z-26.258
    N79 Z-44.031
    N80 X29.478
    N81 X31.478 Z-43.031
    N82 G0 Z-0.531
    N83 X24.678
    N84 G1 Z-24.158 F0.2
    N85 X27.078 Z-25.358
    N86 X29.078 Z-24.358
    N87 G0 Z-0.531
    N88 X22.278
    N89 G1 Z-3.076 F0.2
    N90 X22.642 Z-3.258
    N91 Z-22.172
    N92 X22.587 Z-22.22
    N93 Z-24.031
    N94 X24.423
    N95 X24.678 Z-24.158
    N96 X26.678 Z-23.158
    N97 G0 Z-0.531
    N98 X20.567
    N99 G1 Z-2.22 F0.2
    N100 X22.278 Z-3.076
    N101 X24.278 Z-2.076
    N102 G0 Z-0.531
    N103 X20.056
    N104 G1 X18.856 F0.2
    N105 Z-1.365
    N106 X20.567 Z-2.22
    N107 X22.567 Z-1.22
    N108 G0 X23.842
    N109 Z-22.22
    N110 X23.787
    N111 G1 X22.587 F0.2
    N112 X20.496 Z-24.031
    N113 X22.587
    N114 X24.587 Z-23.031
    N115 G0 X49.878
    N116 Z-68.686
    N117 G1 X48.678 F0.2
    N118 G3 X48.101 Z-69.381 I-2.8 K0.755
    N119 G1 X47.004 Z-70.331
    N120 X48.678
    N121 X50.678 Z-69.331
    N122 G0 X49.878
    N123 Z-0.531
    N124 X68.678
    N125 Z4.869
    N126 G97 S927 M3 M41
    N127 M9
    N128 X200. Z200.
    (PROFILE FINISHING2)
    N130 M1
    N131 T020202
    N132 M8
    N133 G95
    N134 G97 S1000 M3 M41
    N135 G0 X70. Z5.
    N136 G50 S3000
    N137 G96 S220 M3 M41
    N138 G0 Z0.883
    N139 X20.13
    N140 G1 Z-1.117 F0.15
    N141 X23.765 Z-2.934
    N142 Z-21.507
    N143 X20.886 Z-24.
    N144 X26.131
    N145 X30. Z-25.934
    N146 Z-44.
    N147 X43.2
    N149 G1 X52.828 Z-48.814
    N150 Z-65.986
    N151 X50. Z-67.4
    N152 G3 X49.357 Z-68.6 I-2.4
    N153 G1 X50.392 Z-70.532
    N154 X50.394
    N155 G0 X70.
    N156 Z5.
    N157 G97 S1000 M3 M41
    N158 M9
    N159 X200. Z200.
    (THREAD2)
    N161 M1
    N162 T030303
    N163 M8
    N164 G95
    N165 G97 S1000 M3 M41
    N166 G0 X74. Z5.
    N167 G0 Z12.3
    N168 G71 X20.764 Z-22.5 D0.15 H3. F3. M32 M73
    N169 X74. Z5.
    N170 M9
    N171 X200. Z200.
    (PART2)
    N173 M1
    N174 T070707
    N175 M8
    N176 G95
    N177 G97 S416 M3 M41
    N178 G0 X70. Z5.
    N179 G50 S1000
    N180 G96 S91 M3 M41
    N181 G0 Z-73.
    N182 G1 X-1.6 F0.075
    N183 X70.
    N184 G0 Z5.
    N185 G97 S416 M3 M41
    N186 M9
    N187 G0 X200. Z200.
    N188 M2
    Jun 2015
    4190
    Re: Okuma OSP U10L 2286-13 Alarm B Plus variable limit over Z-Axis 2
    hy try N171 X200. Z200. T000300, in order to cancel active offset; thus, when using T folowed by 6 digits, replace last 2 digits with zero's, then retreat to home position
    give it a go, it should work
    Code:
    (THREAD2)
    N161 M1
    N162 T030303
    N163 M8
    N164 G95
    N166 G0 X74. Z5.
    N167 G0 Z12.3
    N169 X74. Z5.
    N170 M9
    N171 X200. Z200.
        indentation & alignment
        removing extra N***, and adding a single one for restart purpose
        M41 - M42; i doubt you can reach 1k in 1st gear :)
        whenever possible, avoid lines with single G or M codes, like M1 M8 M9 G95, etc
        check if your control supports Z5 instead of Z5.; maybe there is a parameter ...
        M33 may be better than 32
        NAT03 T030303 M1 ( thread 2 )
        G97 S1000 M3 M42 M8
        G0  X74     Z5
        G0          Z12.3
        G71 X20.764 Z-22.5 D0.15 H3 F3 M32 M73 G95
        G0          Z5
        G0  X200    Z200 M9 T000300
        removing useless repositioning codes
        G97 S1000 M3 M42 M8
        G0  X74     Z12.3
        ctr for osp u10L, but i am not sure if it works, because i don't have acces to u10L
        G97 S1000 M3 M42 M8 G0 X74 Z12.3 M63
        ctr for osp300
        NAT03 T030303 G97 S1000 M3 M42 M8 G0 X74 Z12.3 M63 ( thread 2 )
        G0  X200-VETFX Z200-VETFZ M9 M203 M1
        modulation
        N***** CALL ODTHREADING LS=1000 LF=3 LX=od LZ=z_end LDOC=rough_doc LFIN=finish_doc ( LQ=2 will deliver 2 spring passes )
    Apr 2009
    1273
    it looks like you never went back into a G00 mode after your threading cycle. Put that in and you should run fine. I'd also suggest you use an M203 on your rapid to limit lines so the turret unclamps on the way home. Using the T command along with the XZ positions will allow the turret to clamp as it rapids to the part. These simple changes should be good for several seconds off of your cycle.
    Best regards,
    Experience is what you get just after you needed it.
    Oct 2020
    4
    Hello, my name is Rocky Weber an I am a senior engineering student in high school in Ohio. For my capstone project, I am planning to convert a 3d printer in a desktop router. If you have time to take a quick, easy 10 question survey I would greatly appreciate it.
    https://docs.google.com/document/d/1...7MjoB9bMY/edit
    Jun 2015
    4190
    good eye mr wizard, i didn't noticed that rapid is missing
  1. Okuma-U10L DNC
    By hense in forum Okuma
    Last Post: 01-02-2025, 04:50 PM
  2. okuma osp u10l
    By TOMO1 in forum Post Processor Files
    Last Post: 08-03-2017, 01:44 PM
  3. okuma OSP-U10L
    By clayd-cnc in forum Okuma
    Last Post: 09-20-2016, 10:51 AM
  4. OKUMA OSP U10L 813 ALARM-P
    By Birkas in forum Okuma
    Last Post: 08-26-2016, 09:46 PM
  5. Post for Okuma Osp-U10L
    By Pupc in forum Post Processors for MC
    Last Post: 04-01-2016, 02:56 PM
