603,354 active members*
3,754 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA OSP U10L 813 ALARM-P
Results 1 to 7 of 7
    Oct 2010
    I change the SRAM and initialisation memory A;H . Thereafter software load ( I have only 6/6 floppy for the machine , Backup don't. Power off and on , the machine start with 813 ALARM-P Servo link communication error 20000' S1-1-31'
    S-LINK INFORMATION [COND.]-[CH.]-[S.NO]-[ID.NO]-NAME-BOARD
    1-1-1-XA-1CB1B105
    1-2-3-ZA-1CB1B105
    PBU FILE ON LOADING
    FIRM WARE FILE ON LOADING
    SBP MONITOR
    Any good idea ?
    Thanks .
    Mar 2009
    1992
    look for orange (optical) cables inside main control cabinet. Careful - these are very fragile. Check them if they connected properly and if they work
    Aug 2011
    459
    Did you solve this problem?
    Quote Originally Posted by Birkas View Post
    1-1-1-XA-1CB1B105
    1-2-3-ZA-1CB1B105
    PBU FILE ON LOADING
    SBP MONITOR
    Any good idea ?
    Thanks .
    Oct 2010
    Yes . The MIP 11 Spindle servo control card is bad. We order from GIOCOM SOURCING USA
    Nov 2015
    Re: OKUMA OSP U10L 813 ALARM-P
    i have this problem also 813 ALARM-P Servo link communication error 20000' S1-1-31'
    1-1-5-SA-1CB3V613
    Dec 2014
    3
    Hi Friends
    I have okuma OSP 7000 Control
    after months of being off now we lit and does not start the boot
    I have the diskettes but I need to know how I can
    upload this information to the control
    Please appreciate if I can help
    Apr 2009
    1273
    Go to electrical cabinet of the machine and turn on load switch. Then press system reset pushbutton. Follow screen prompts for installing software disks. When finished, turn off load switch and press system reset again. Machine should boot, but parameters, etc. will need to be loaded.
    Best regards,
    Experience is what you get just after you needed it.
  1. Okuma-U10L DNC
    By hense in forum Okuma
    Last Post: 01-02-2025, 04:50 PM
  2. okuma OSP-U10L
    By clayd-cnc in forum Okuma
    Last Post: 09-20-2016, 10:51 AM
  3. Okuma OSP-U10L some features missing?
    By compuslave in forum Okuma
    Last Post: 04-23-2009, 08:35 PM
  4. OKUMA OSP-U10L RS232
    By edmondyjh in forum Okuma
    Last Post: 01-28-2009, 08:27 PM
  5. OKUMA OSP-U10L RS232 SETTINGS
    Last Post: 09-25-2008, 08:13 PM
