587,460 active members*
3,407 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA Remake Software
Results 1 to 5 of 5
    Aug 2011
    421
    We have an LB15 OSP5020 control unit. CNC is running smoothly but we haven't remake floppy(Control software). Is there a way, making control software from CNC?. I can copy all files to floppy diskette from CNC memory. How do i convert it to control software?
    Mar 2009
    1982
    you can make system backup using Central control mode "S". There are at least two mode control switches in Main Control Cabinet. One is "overtravel release" and other one, next to "reset" is control mode. Select maintenance mode and your control boots up to maintenance menu. You can re-install from there and you can make a backup copy from there. I'm not sure, if it makes bootable, tihe 1st one floppy.
    but first. First You make sure, is the floppy the device for system restore. Paper tape reader could be the one for such an old machine
    Aug 2011
    421
    Files
    There are fifteen files in CNC memory (BB0: ), but files must be sixteen in remake floppy. Sixteenth of the file extension should be BBM (etc BIN**-***-B.BBM). This file is not in the CNC memory (BB0: )
    Jan 2009
    74
    The software can't be "built" from what is stored in memory. First is the BIN files issue, which is part of the loading process and sets size of memory and format, next are the pbu data files which can't be copied because of a file sector issue. If you don't have the software you would have to purchase another full loadable set.
    Aug 2011
    421
    I understand but very expensive price for the one 1.44 floppy.
  1. Okuma Cadet Software
    By ryanh114 in forum Okuma
    Last Post: 02-02-2023, 11:51 AM
  2. okuma lathe programing software help
    By ironmike2682 in forum Uncategorised MetalWorking Machines
    Last Post: 02-14-2013, 02:58 AM
  3. Software For Okuma LR15
    By ryantj21 in forum Okuma
    Last Post: 10-31-2010, 09:23 PM
  4. Okuma CNC OSP 500L-G --- Cam Software
    By rajappa in forum Okuma
    Last Post: 06-18-2008, 01:21 PM
  5. New Software for Okuma
    By psevin in forum News Announcements
    Last Post: 08-15-2006, 04:25 PM
