See if this file helps you.
Cheers
Brian.
Cheers
Brian.
Hi all,
thanks for taking out time for valuable time out of your schedule, I tried all ways but had no luck, finally, I shifted to a floppy emulator and just got it for 100 $ and communication is also faster,
Now facing BUFFER OVERFLOW for bigger programs than 60 kb, can anyone please share a program format for how to call a multiple subprogram from main program?
it is called "shedule program". The program which calls part programs ( loacated on separate files ).
hy sunilb, as allready mentioned in a previous post by kurmay, this can be fixed, so to enlarge available program sizeNow facing BUFFER OVERFLOW for bigger programs
it's a way better alternative than schedule programs *.sdf
please feel free to ask any question / kindly![]()
Hi
The controller on the machine is U10M,
can you still help.
Gratitude Kitten,
I am new to CNC machines, just learning by experience/youtube/forums ??, the machine is working well at this moment with small programs running turn by turn, I will try *sdf in the week to come.
Thanks & Regards to all for such friendly behavior.
- - - Updated - - -
Hy sunilb, if you wish for buffer size increase, please share an e-mail / kindly![]()
Hy Kitten, you can mail me at [email protected]
please notify me after its sent, some times it goes to spam folder
please contact [email protected]![]()
sent it
Can you tell me if the 1998 LB25ii on the way to me will use the same RS232 settings as the MC4VA I currently run? The MC4VA and Fanuc 10T use the same settings in the dnc software now. I'm worried there are a LOT of things I'm going to have to figure out with this new machine. Never ran OSP lathe before. Which canned, tapered threading cycle is a big worry. Loren
In my opinion following "the good configuration" from other machine is wrong approach. You need a good cable and matching settings on both sides.
If the setup is working for Fanuc DNC it doesn't mean that it is suitable for OSP file transfer.
