588,173 active members*
4,599 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Okuma turning cycle, using rough & finish tool
Results 1 to 4 of 4
    Dec 2006
    26
    I need some help with an Okuma G81type turning cycle, using rough & finish tool. I need someone to post an example of the code needed to rough turn and finish turn the OD of a steel part. I have the code for using 1 tool but don't know where in the cycle to insert the tool change to do the finishing to my part. Right now I am writing two different programming cycles and it would be nice to just write one canned cycle that will do the entire turning cycle. I am setting up on an Okuma 5020L control. Thanks for any help! Barney
    Dec 2006
    26
    Re: Okuma turning cycle, using rough & finish tool
    Here is an example of what I'm using right now, works ok but I need to rapid back and change tools to the finish tool, just don't know where to put the tool change, please post a program example of how you would do that, thanks
    G0X20.Z20. (12-12-2012)
    G50S1200
    G97 S600 T010101 M03 (TOOL 1)
    G00 X2.78 Z0.3
    M8
    N1 G85 NAP1 D.2 U.01 W.002 F.01 G84
    NAP1 G81
    G00 X0.90
    G01 G42 Z0 F0.01 (G42)
    X2.1 F0.005
    X2.245 Z-0.075
    Z-1.063
    X2.78
    Z-2.01
    X3. F.03 M9
    G0 G40 Z.5
    G80
    N2 G00 X20.Z20.
    Dec 2008
    3136
    Have you looked in the OKUMA forum ??
    many examples already posted
    Jun 2011
    124
    The manuals are very available with some googling
  1. Replies: 3
    Last Post: 05-12-2014, 02:50 PM
  2. Replies: 15
    Last Post: 05-09-2014, 12:55 PM
  3. Problems with rough finish
    By 44-henry in forum Tormach Personal CNC Mill
    Last Post: 06-02-2009, 06:43 PM
  4. How to rough/finish threadmill in MCX?
    By John_B in forum Mastercam
    Last Post: 07-27-2008, 04:25 PM
  5. Very rough finish when turning 6061-T6 ... why?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2008, 11:24 PM
