603,964 active members*
2,159 visitors online*
Results 1 to 9 of 9
    May 2003
    11
    Old cnc tool holders
    I have aquired a large lot of straight shank cnc/nc tool holders and I am trying to identify them. Here is a sample part number:
    Erickson Tool #150 btg
    bmi c100104..311802
    These were used on machinery with a tool changer and have the retention knob on the back. Does the industry designation appear anywhere in this part number? If not, does anyone know a site or some way to identify the item? I have pics if needed.
    Thanks...gary moore
    Mar 2003
    507
    Welcome to the forum Gary!
    Upload the photos in the ftp section. I'm sure someone will recognise the holders and have the right answers. I'm sorry the name Erickson does not ring a bell....
    Klox
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
    Mar 2003
    4826
    If nothing else, Erickson tooling is available as a subline from Kennametal.
    First you get good, then you get fast. Then grouchiness sets in.
    May 2003
    11
    Toolholder Images
    I didnt know how else to do this so I attached it. I hope I didn't break any rules...thanks...gary
    May 2003
    11
    Toolholder Images
    Here is another:
    May 2003
    84
    Hi Gary,
    HuFlungDung is correct, Kennametal is the only retailer of Erickson tooling. I have a few old Kennametal catalogues at the shop and I'll see if there is any info on your holders. I'll let you know.
    Adam
    Mar 2003
    6855
    No :banana: you did'nt break any rules.:rainfro:
    Apr 2003
    77
    I;m not 100% sure but I think the tool holder came out of an White sunstrand Omni mill
    Can the retnsion knob be adjusted for differant lengths?
    Is the shank 2.000 in diameter?
    If yes to both of these then I would be farly confindent with this.
    May 2003
    11
    Eureka!
    Why yes! The Shaft is exactly 2". and the retention knob has a thin locking nut which probably be used to adjust the length. I was talking to one of the machinists from the plant that they came from and he mentioned a "White" Boring mill?
    Was this the only machine that you know of that they were used on?
    Sincere thanks...gary moore
  1. Gang tool cnc mini?
    By Call Maker in forum Mini Lathe
    Last Post: 03-26-2006, 06:38 PM
  2. Tool holders
    By zachf in forum CNC Machining Centers
    Last Post: 01-28-2005, 12:17 AM
  3. Tool changing with endmill holders
    By febisfebi in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2004, 06:33 AM
  4. Machine Tool Camp 4'x8' VS Cad Cut CNC 4'x8' Router
    By Trimix in forum DIY CNC Router Table Machines
    Last Post: 12-18-2003, 08:49 PM
  5. Are there Camsoftcorp users out there?
    By HuFlungDung in forum CamSoft Products
    Last Post: 11-13-2003, 10:12 PM
