603,316 active members*
2,941 visitors online*
IndustryArena Forum > CAM Software > Mastercam > old machine mark century 1050 monarch 150
Results 1 to 7 of 7
    Oct 2010
    HA:
    We have two Monarch VMC150 that are run by a GE 1050 controler these machines were made in 1980 but nothing on the market today will out power them. We have post for them but they are not perfict yet, but if someone has one that they think is good we would love to try it. we have problems when it comes to helical z moves where you have to use radins for your z distance .
    Jun 2005
    305
    Geez Louise, my 1st controller from 1983.
    Brings back fond memories. *sniff*
    If I remember correctly, it only uses linear Z values for helical moves, like most FANUC compatable controls.
    Also, it will only accept the LAST axis letter per line.
    Meaning, no more than 1 N, G, X, Y, Z, M, etc. per line.
    Check your post output for multiple axis codes per line.
    Does your control have the 8 line neon dot-matrix display or the single line display?
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Oct 2010
    ObrinenDave:
    thanks yes it is an 8 line control that moves the op. line to the top at all times. they are strong machines and work great with big cutters you don't have to run very fast 3500 max rpm.
    when we are asking it to run in g18 g19 mode you have to write z in radins so the control can get it's speed correc t for the diff axis's
    Jun 2005
    305
    Not 100% sure I follow you.
    Are you using an R word for defining a G18 and G19 arc?
    I remember using a signed incremental value for the arc center point.
    Can you post a little bit of the arc code along with the appropriate G18 and G19 so I can have a look at it?
    It's been 10 years since I used that control.
    Does your control have the subroutine option with parameter programming?
    How much memory do you have?
    Mine had 32K.
    Mar 2006
    1013
    Radians for the arc? I dont ever remember seeing that one on the 550 or 1050's. I remember having to calculate a Vector to activate cutter comp. That was a major PIA.
    I'd also like to see some code.
    Are you running off of tape?
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Oct 2010
    ObrienDave
    in the z axis when cutting an arc you use a k, R is only for your z ref. pos
    we do run subroutines with parameter programming and we have 64 k of memery
    Oct 2010
    Mike Mattera
    we are using a btr to run to the memery. or drip feed if we have to because of size.
    Radians for the arc yes but only in z axis so the two axis start and finish at the same time we use a K for the radian of the arc. the machine will set the speed of z to make everything happen.
    thanks
  1. ge mark century 550 memory battery
    By Daniel Wilcox in forum Controller & Computer Solutions
    Last Post: 06-13-2024, 04:25 PM
  2. GE Mark Century 2000 Manual
    By RDMoore in forum G-Code Programing
    Last Post: 03-05-2016, 09:27 PM
  3. Mark Century 2000 Dnc Problem
    By ozgurm in forum DNC Problems and Solutions
    Last Post: 02-18-2009, 06:22 AM
  4. GE 1050 mark century N17 error
    By eastpaman in forum News Announcements
    Last Post: 01-21-2009, 03:42 PM
  5. Replies: 0
    Last Post: 03-31-2008, 04:55 PM
