603,417 active members*
1,981 visitors online*
    Jan 2007
    333
    old Mori lathe won't Home
    Hi All,
    My buddy has an old Mori lathe with a 10T control and absolute encoders. Yep, the batteries died in storage and now we're wanting to powerup and run this machine. We didn't lose parameters but get an alarm when trying to zero return the machine..... something about improper position something or other. I think on an OT control you simply hold "P" and "CANCEL" on powerup and it allows you to home. Anything this simple for an old 10T control?
    Any help is appreciated.
    Aug 2007
    36
    Call Mori Service
    Call Maruka their service is great. I had a similar problem with my Mori Milling machine they had me up and running in 20 min.
    PPM Inc.
    Hudson ,Fl
    Sep 2008
    24
    Normally after the battery died, the absolute servo position will no longer in memory.
    The alarm appeared will be something like Z/X Need Zero Return (ABS)
    It'll be better if you could indicate the actual alarm on the screen when you power on the machine. That might give us more info on what you are actually facing.
  1. Fanuc SYSTEM 5/Mori lathe set-up
    By HapSmo19 in forum Fanuc
    Last Post: 01-21-2009, 09:48 AM
  2. Mori Seiki SL-403 Lathe
    By alc1960 in forum Mori Seiki lathes
    Last Post: 09-23-2008, 03:35 PM
  3. manual chuck on mori lathe
    By SHKROHN in forum Mori Seiki lathes
    Last Post: 09-22-2008, 04:50 PM
  4. nam sun lathe/mori seiki knock off
    By jheyliger in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2008, 07:42 PM
