Do you have the Fadal software Assist program? It will allow you to run programs larger than 32K using DNC method. Where I work we have one cnc88 control with only the 32K memory. With programs larger than the memory I just ran as DNC. Since the shop now had newer Fadals with much more memory. It is now a non-issue. To make the program DNC ready, strip out the extra comment blocks not needed to run the program and change the M2 at the end of the program to an M0. And the program must be sequential, no M99P(N block number) blocks branching back.
Safety - Quality - Production.
